big axles question guy!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Sep 12, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    i have 1/2 running gear on my truck i wanna put 38 inch tires on my truck with a 7 inch lift but that aint the problem i wanna know what i can do to my axles to make it work on and not break becuase i like the ground clearance of the 1/2 stuff.....im thinking of puttin mooser 30 spline axles in there would that help put or ??? i need as much advice as i can get thats alot .
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Aftermarket BEEF!
    Get On ORD's web site and spend 1500 on the front for axels, hubs, differential, hub fuzes to help save thoes 297 Ujoints cuz anything bigger than a 35" on 1/2 ton you are gonna bust a ujoint from time to time. As for the rear new axels and diferential is realy all you can do, well oversized driveshaft too and some kind of truss....
    You perty much need to get rid of the stock guts and go aftermarket.
    Then you will need to learn throtle control when wheeling to help prevent the POP that will occur with thoes big tires....
    Good Luck
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    ok thanks so u think it might work becuase i wanna kinda wanna keep the 1/2 becuase i like the ground clearance ya know ?
  4. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    why not trim a 14b Itrimmed an 1" off mine or go d60 and trim it its gonna be cheaper.
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.11
