Big Axles!!!!!!
Discussion in 'The Garage' started by sta500666, Dec 19, 2004.
  1. sta500666
    sta500666 1/2 ton status
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    I have an 86' K-5, and I'm tired of my pussy half ton axles. I am thinking of getting a Dana 60 front, and a GM corporate 14 bolt rear. I am planning on making my Blazer into a mean indistrucktable off-road machine. I was just wondering if those big axles are the way to go, because I have been watching the Trucks T.V. marathon, and he is using a lot of Dana 44 fronts, and Dana 60 rears, or 9 inch rears. I guess all I want to know is will those axles work good for some heavy duty off-road abuse?
  2. chaplain X
    chaplain X Newbie
    Dec 15, 2004
    4
    oregon city OR.
    Just depends! how much you want to spend?aftermarket axles and U-jionts arent cheep! and a 60 front end is not that much $$$$$ when you compare it to replacement parts on a regular basis...I guess it all depends on so meny variables!!!!$$$, tire size, what kind of wheeling and what realy is youre def. of hard use!!!!!! big axles= good insurence that you wont be replacing parts on a regular basis!!!!!
  3. sta500666
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    Yeah, I'm probably only ganna lift it 4 or 6 inches, and put 35's or 36's on it. I just want it to be able to tow, and do some seriouse mudding and trail riding. I'm not into rock crawling to much, but you never know. I guess if I were going to make a rock crawler I would use a smaller differential for more clearance. All I want is streangth and reliability on the trail.
  4. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    With 35's or 36's I suggest getting a 14 bolt in the back and maybe a 3/4 ton front dana 44. Once you get above 37's or so then start looking for the dana 60's etc etc. It all really comes down to how you drive your truck (AKA How much skinny pedal) and how big your wallet is feeling.
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    ....and everything on QVC is the highest quality at a great price. dont use Trucks as a model to building a functional truck.
  6. chaplain X
    chaplain X Newbie
    Dec 15, 2004
    4
    oregon city OR.
    SLY Dog is correct!!! smore skinny pedle means more money!!!!If you are mostly gonna tow and light offroad, 14blt and a heavy dana 44 would be fine!!!!And you dont have to go rock crawling to brake lots off parts....but there is no dought that it is probebly the worst thing you can do to a 4x4.....dont get me wrong! if there is 2 things I love its lots skinny peddle and emoveable objects .......
  7. sta500666
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    Yeah, well I still think if I can find a good used Dana 60 front for cheap I'll probaly get that just to have it you know, but if not a Dana 44 will do just fine. I definatly want the 14 bolt to be a full floater just incase I ever snap an axle. Thanks for the tips.
    Hey, also does anyone know what a good gear ratio would be? I have heard 4:10 is really good, but I'm not sure.
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Rotflmao:haha: :haha:
    That's really funny!
    Rene
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not to mention, even if you do find it, they're expensive just to get installed.
  10. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    if you want a good axle mog 406 or 416 best ground clearence and the strongest axle you can get
  11. chaplain X
    chaplain X Newbie
    Dec 15, 2004
    4
    oregon city OR.
    were is the best place to get those mog axles?????? and arent they (very exspensive)!!!!!!!!!!!!
  12. 78blazaer
    78blazaer Registered Member
    Aug 15, 2002
    36
    My suggestion, GO BIG. I did and I am very satisfied. About six months ago, I have the same questions, what upgrade should I do with my rear ends. After surfing several 4x4 web sites, I learned that the best and most economical way to go GM 14 bolts rear, Dana 60 front. Here is why:
    REAR: GM 14 BOLTS
    1. GM 14 bolts is heavy duty. You'll see them on 3/4 -1 ton trucks.
    2. 8 huge wheel lugs compare to six little tiny peanut size lug bolts found on 10 or 12 bolts.
    3. GM 14 FF brake shoes and drums are huge. More breaking power. You can also convert the rear brakes into disc brakes later if you wish.
    4. Since it is a full floaters, you can pull the axle off without pulling the wheel off.
    5. Unlike 12 or 10 bolts diff, the weight of the vehicle doesn't rest on the axles, that is why they call it full floaters.
    6. Cheap! You can get one from you local junk yard for less than $300 bucks.
    FRONT: DANA 60
    1. Way superior than Dana 44.
    2. Stronger axles.
    3. Massive brake rotors (huge 8 lugs). Again, more braking power.
    4. Perfect for crossover steering or high steer project. Unlike Dana 44, you will have to look for a flat top knuckle if you wish to do a cross over steering, which by the way a must for GM trucks.
    Some people say Dana 60 is expensive but if you add up the cost of doing a cross steering and beefing up your axle on a Dana 44, or converting your rotors from 6 to 8 lugs like the one found on 3/4 ton trucks, you will ended spending more or close to buying a used dana 60.
    Save your money and hunt for a 60. Good luck!
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    And then on top of the cost of the axle itself, it needs brakes, seals, crossover, hydro ram, etc. that's what makes a '60 so expensive.
  14. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The only reason to go to a 3/4 ton front is to get matching 8 lugs if that is what you upgraded to in there rear.
    3/4 ton fronts are no stronger than 1/2 ton fronts. Just larger disc brakes.
  15. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Yes but who would spend the time changing gears and hubs in their old 1/2 ton front to match the rear when they could just go buy a matching 3/4 D44 or 10B for a 1/3 of the cost that it takes to swap gears and find 8 lug hubs.
  16. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I would be more interested in a set of 4.56's with 35's. 4.10's will work which is what I have but wish I would have held out for a set of 4.56 geared 3/4 axles.
  17. 78blazaer
    Aug 15, 2002
    36
    That is very true. I ended up shelling out an extra $1800 for my RAM assist and crossover steering project. But you don't have to do this right away, you can leave the stock steering (it wont be as good) but you can get by with it for awhile until you have the money for steering upgrade.
    Do it gradually. Do the crossover steering project first, then do the RAM assist later, etc..
  18. sta500666
    Apr 16, 2004
    291
    Dubuque/Ames, Iowa
    Hey, thanks for all the tips. By the way Dana 60 fronts arn't that expensive. I fouund some cheep ones on Ebay.
  19. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Dana 60 is a good front axle, and as far as the rear goes, a midly built Ford 9 inch will outlast a stock 14 bolt FF, while being a lot lighter with more ground clearance (smaller pumpkin) :)
  20. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    pshh...forget the 9", get an Eaton H052 or H072...they are like a 9", only on steroids :D
