Big block build and transmission options
Discussion in 'The Garage' started by Jagged, Apr 1, 2007.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    I'm building a big block for my '89. 454, .040 over, 427T heads, just under 9:1 compression, and crane's truck cam for idle-4600 (.485/.485 266/266@.050").
    Right now the truck has it's original 700R4. I can rebuild the 700R4 using the tightest tolerances, but I really don't think it will last. I'll be running 3/4 ton axles with 3.73's. With 31-33" tires my rpms at 65 MPH on another transmission (TH350/TH400/SM465/etc) with a 1:1 final drive is from 2628-2469 RPM. With overdrive, I'm only turning 1802 RPM.
    So, we're looking at almost a 1,000 RPM difference between overdrive and a 1:1 final.
    Basically, I want to drive 65-70 MPH without my 454 sounding like it's gonna explode. Thoughts, comments, suggestions?
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    go 465 and never look back!
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,031
    1,347
    Kzoo, Mi
    I really don't know why people think 2800 rpm is excessive, most of these engines dont make max torque until close to 4000 or more. If your only running 26-2800 it would be perfect cruising range. Maybe not real great on gas, but if your running a BB that shouldn't be a concern anyway.
  4. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    X2...
    My 305 will cruise around at 3250 rpm all day long.
