Big Block "cam oiling clips"?
Discussion in 'The Garage' started by Zeus33rd, May 5, 2003.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Big Block \"cam oiling clips\"?
    What are these things? How do they work? Where do they go? Where can I get them? Pros? Cons?
    Just curious cause of the flat cam I have now...Got a new Extreme 4x4 cam and lifters, and I don't want the same to happen again. I know the big blocks are known for eating cams/bad cam oiling...I want to prevent it from happening again. /forums/images/graemlins/pimp1.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Re: Big Block \"cam oiling clips\"?
    PM Shawn...he has one on his 496...pretty simple and cheap deal...Personally though, if the cam is broken in correctly, a flat lobe should be a moot point...just use lots of the red assembly goop and run it...thats just me...I know that the system that Shwan has requires drilling and tapping the oil galley...no a good idea unless you like the idea of metal chips floating round your motor /forums/images/graemlins/eek.gif
    Chris
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    never mind..i thought you were talking about the overhead cam oiler that plugs into you cam oil galley...I don't know about the clips...
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thats exactly what I was refering too, I just couldn't remember what they were called. And I didn't realize it required drilling and tapping..lol. TO much work. I'll just do like you said, assembly lube stuff, proper break in and hope for the best. /forums/images/graemlins/smile.gif /forums/images/graemlins/k5.gif
  5. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    go to off road .com search for BC ENGINEERING, overhead
    auxilery cam oiler,prodject potent rodent, theres a little
    more to it than the article says,if you order it bob will
    fill you in on the what nots, /forums/images/graemlins/thumb.gif
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    OKay cool we are on the same page then /forums/images/graemlins/thumb.gifYeah , I don't know why Shwan got it b/c his 496 is a roller cam motor and doesn't need the extra oil really...Oh well...a good set of lifter and a good cam (which you already have) /forums/images/graemlins/thumb.gif when broken in properly will do just fine...Do you have the stock pressure springs on your heads or do you have heavy springs? if you have heavy-seat pressure afermarket springs, I suggest that you swap in some low-pressure springs for the break-in period...With radical springs, even the perfect break-in technique and all the proper precautions can leat to a flat lobe /forums/images/graemlins/eek.gifjust a thought...
    Chris
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Well, I'm kinda shooting blind on the springs. My guess is that they are not stock stuff. I bought the truck this motor was in for $300. Had a blown head gasket. But whoever built it did it right I think. It has Harland Sharpe full roller aluminum rockers. The part number on the lifters is a Comp Cams part#. 427 heads on a 402 block. HV oil pump, balanced crank, forged pistons. The guy that did the head job for me said it had stainless still intake valves, or something liek that, I dont remember. So I figure if it has all that stuff, it might have the heavier springs. I was looking at getting the Comp Cams 911-16 springs. or 916-11, I cant remember.
  8. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I did the cam oiler since I thought I was going with a standard cam/lifters then I changed my mind to a roller cam after the oiler was done. I figured it wouldn't hurt to have it. Someone else mentioned cutting grooves in your lifters to help oil the cam. I think Comp carries a tool just for that. For any cam/spring/lifter questions, I frequently turn to Comp and call their 800 number.
