Big block Chevy valve sizes?
Discussion in 'The Garage' started by madmike, Jan 13, 2003.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I'm in the process of thinking about rebuilding a 1972 402 rat engine for my truck. The motor I have ran ok when pulled, smoked and leaked oil, unknown mileage. I'd like to rebuild it, but I haven't torn it down yet. I'm looking to build an engine with around 9:1 compression, and to make a lot of torque at low rpm. Except for cam, intake, Qjet, and maybe headers, I'd like to stay pretty stock. My cylinder head casting number is 6272292, and the Mor-Tec website lists this as an open chamber oval port head. Does anyone know what the intake and exhaust valve sizes are? head cc's? Would this be a good head for the kind of engine I want to build? Thanks for your opinions.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Are they 2.19 and 1.88's, or are they the small valve heads?
    Mike
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    They are probably 2.06/1.72's. They can be enlarged to 2.19/1.88's. I would spend the $ to go bigger.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Bulding an engine for low RPM torque you want small valves and intake runners because it will build velocity which will make for the good low RPM torque he is looking to achieve.
  5. madmike
    Jan 23, 2002
    496
    ohio
    I don't know if they are small valve heads or not, that's why I posted this, in hopes someone might know. I really don't want to disassemble the engine until I figure out if I'm gonna use it or not. From what I've been able to read, they're probably 2.06/1.72's, which as 4X4HIGH correctly said, would be better for building bottom end torque.
  6. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    I have seen a test in one of the hot rod magazines that proved the oposite. They took a 454 with a very mild cam and small valve heads and dynoed it. They then swapped the heads for a stock set of big valve heads with the same combustion chamber and cam and the motor made quite a bit more low end torque with the big valves. I think that with the low lift the bigger valves allow so much more flow that it outweighs the velocity improvement of smaller valves.
    Mike
  7. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    *I think* the 292 heads are small valve heads with the small valves. I'll look tonight and see if tat casting is listed in the books I have.
    IMHO as for the magazine test, if the camshaft was changed I don't think that's a fair comparison with respect to head flow characteristics.
  8. madmike
    Jan 23, 2002
    496
    ohio
    nvrenuf, thanks for checking.
    Mr.Chevy4x4, I hadn't thought of it that way, that's a possibility I suppose.
  9. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Okay here is the formula for figuring maximum valve sizes. .52 * Bore in inches for the intake, and .80 * Intake valve in inches for exhaust. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  10. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Where is this formula from? Seems pretty accurate for the engines I'm running too. I run a 427 with small port, small valve heads, GM marine cam (.500 lift, 218I & 228E @ .050)and have plenty of low end power.
