big block diesel engine
Discussion in 'The Garage' started by the general, Feb 7, 2005.
  1. the general
    the general Registered Member
    Oct 2, 2004
    96
    prinsenbeek(the Netherlands)
    does a GM 7.3 liter(turbo) diesel fitt in a blazer k5 ? with tranny (manuel or automatic) will be the best option ? and which transfer case is the best option? :confused: why a diesel ? less electronics and more low end power!:cool1:
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Say wha?
  3. Tenpack
    Tenpack Registered Member
    Feb 7, 2005
    16
    Vancouver, B.C.
    ford makes the 7.3L turbo diesel. From what i know, GM makes a 6.2L and a 6.5L, but no bigger.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm not sure what motor you're talking about either.
  5. the general
    Oct 2, 2004
    96
    sorry guys, i thought that GM made a 7.3 too:crazy: ! but i was wrong! or not? in The Netherlands were i live they say a 6.2 is not the best engine you can get for a blazer i heard that they have alot of problems with the diesel pump and a 6.5 should not be that good too! soo i thought maybe there a bigger engine which is better and has more horsepower and torqe maybe one out of a bigger truck(why a diesel ?) 1 gallon or gasoline costs about 8 !!!! dollars here:cool1: (yes you are seeing it good )soo now you now why i wanne now more about a diesel engine.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    6.2s suck. 6.5Ls are pretty decent actually, and 6.6s are the ****! Those are the new Duramax motors. There is the Cummins 6BT thats the motor I would go with. 6L 6 cylinder that has been swapped into our rigs before.
  7. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    GM used to make a 500ci (8.1L?) Diesel Big Block for industrial applications. The thing was highly regarded as a big piece of junk, though.
  8. BlueBlazer
    Feb 15, 2001
    1,940
    I call BS unless you can establish proof.
  9. OrangeCrushK10
    Jan 25, 2003
    1,425
    Calling BS on the 500ci diesel? They stuck them in school busses, motorhomes, and dump trucks, and I think I even heard of some in a boat of some sort.
    Here's a thread I found about it on some diesel page, and I was wrong. 500ci is 8.2L, not 8.1L. Sorry.
    http://www.dieseldoctor.com/messageboard/data/803.html
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Might want to sniff around the Diesel forum here, not really and ORD question. In fact, I'm going to move it there…
    6.2 is a good engine just not very powerful. But it will generally be quite dependable and can get VERY good fuel mileage. 6.5 has more power, but if I recall correctly, there were some problems with dependability in some or all models.
    For other options, a Perkins or Cummins 4BT would fit much easier than a 6BT. They are a bit hard to find here, but I would expect it to be more common in light deliveries over there. Nissan and others (like Mercedes?) also make some nice small diesels that would be relatively easy to adapt.
    TCase is the biggest problem, but engines like the Cummins have a standard bell housing which makes trans options pretty good, and as long as you choose a trans with a standard round rear pattern (or available adapter), you can mount many different tcases. Worst case you could run a divorced case and still keep a reasonable rear drive shaft...
  11. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Re: 6.2
    I've got over 285, 000 miles and averaged 24 mpg my 6.2 '83 blazer before it decided to take a dump. I wouldn't say it sucked. I also have a 6.2 diesel in a '88 high top customized van that had 325,000 on it before a '98 vette took it out by a hit and run.
    Take care of it with maintenance and it last a long time.
    Still say it is a piece of junk. I wouldn't think so.
    Of course that is my opinion and you know what they say about opinions. They are like ass holes, everyone has one!!!!!
    Phillip TK5
  12. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    In a heavy duty truck, yes, throw one in a 1 ton pickup and it would probably just break the frame :doah:
  13. kennyw
    Jun 9, 2002
    13,224
    94
    Russ, I don't think the original poster of this thread is a CK5 member and can't reply to the tread in the Diesel forum. Might want to move it to the Garage instead so he can take part in the discussion.
  14. kennyw
    Jun 9, 2002
    13,224
    94
    I don't have any problems with any of the 6.2L's I have owned in my life. Always dependable, always get good mileage, and just as much power as a stock small block Chevy 350. It will cost a little more to get the power level up on a 6.2L compared to a small block, but it will pay for itself in fuel savings over a gas motor (when you compare the difference in cost).
    The 6.2L that I put in place of a tired 350 in my '79 K20 gets 22mpg around town and about 17.5 on the highway. It has already paid for itself 3 fold in just the money I save filling it up since I do so much driving.
  15. BlueBlazer
    Feb 15, 2001
    1,940
    Its called an 8.2 L DETROIT DIESEL, not a GM big block diesel. Just because it was in GM vehicles doesn't make it a GM diesel, and throwing the big block terminology in there makes it even more confusing for the layperson.
  16. kennyw
    Jun 9, 2002
    13,224
    94
    The 8.2L Detroit is the same basic design as the 6.2L, just larger from what I have seen/heard. It would be considered a big block compared to a 6.2L :tongue1: Lighten up a little, you appear a little tightly wound today.
  17. BlueBlazer
    Feb 15, 2001
    1,940
    Sorry Kenny, but I can't stand misinformation being spread. The 8.2 is nothing like the 6.2. Completely different fuel system, valvetrain, and overall design. Except for the V8 configuration it shares nothing with the 6.2 designwise.
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Argh, didn't think about that... done...
  19. OrangeCrushK10
    Jan 25, 2003
    1,425
    Hey, I never said that I'm a diesel guru. I just said that I've heard of a larger displacement diesel used by GM. It's equivalent in size to a big block, so for the sake of keeping things simple for those who are learning, I gave it the term big block. I didn't mean to put anyones panties in a twist. I was just trying to toss a little bit of info out there.
    He wanted a big displacement diesel from a GM truck, I gave an option. No reason to get all upset about it. :grin: Thanks for the info, though. Now I know better for future refrences.
  20. kennyw
    Jun 9, 2002
    13,224
    94
    I understand trying to correct mis-information, but I didn't see much worth yelling about is all. :thumb: I've never had the opportinity to do anything with an 8.2L though.
