Big block dimensions.
Discussion in 'The Garage' started by mikey_d05, Feb 11, 2007.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Hey guys, could someone with a BBC do me a favor, I need a few measurements.
    I need measurements from:
    -the rear face of the block to the front of the pulleys (doesn't matter if it's serp. or v-belt).
    -outside edge of head to outside edge of head (widest point of the motor not counting the exhaust)
    -bottom of sump to the top of air cleaner
    I'm trying to see if it's feasible to fit a DT466 or HT570 into a chevy.
    Also, what does an all iron big block weigh? A DT466 weighs in at 1400 pounds dry and holds 32 quarts of oil. :doah:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Can't help you with the dimensions portion of your request as i just finished taking apart a 454. I can tell you though that a complete BBC weighs in at 685 lbs.
  3. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks man, think a D60 or 2wd front would handle and extra 800 pounds sitting on it?
  4. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Yesterday, you were less than 20 feet from a BBC that you could have taken measurements from:p::p:
    damn vandal:angry1:
    :haha:
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, but it didn't run worth a damn and there was a hole in the gas tank. :p: Did you guys get it rolling after you drove the 1/2 block to the gas station?
    Actually, the DT466 idea hit me today. I dunno how the hell I'd put a t-case on one though.
    Brett, how much does a 6bt weigh?
  6. Stomper
    May 11, 2002
    3,767
    Iowa
    Runs perfectly after the tank was fixed and it had a drink :haha:
    Run a divorced case.
    6bt is about #1100
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Now go measure a 6bt, I know you've got one. Damn scavenger. :p:
  8. Stomper
    May 11, 2002
    3,767
    Iowa
    Jeez, can't you do anything yourself:p:
    It's too cold, actually it's about 20 degrees warmer today but I'm still not going to do it[​IMG]
    I can tomorrow tho, in the day light.
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks Brett. Drag out a divorced 205 while you're at it. :D
