big block gurus.....
Discussion in 'The Garage' started by midget, Mar 12, 2003.
  1. midget
    midget Registered Member
    Mar 2, 2003
    18
    California
    I'm looking at a couple 454's for the /forums/images/graemlins/burb.gif, 1973 out of a motorhome with 60K miles or 1985 out of a 1ton p/u 80K miles. I am thinking the 73 is better b/c less/no smog stuff, likely a 4 bolt main, coull put it in run it for awhile then it would be a good base for a rebuild with more power.
    If I would be better off looking for a different year let me know. I know things changed through the 70's and 80's but not sure which is better..........
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Go with the 73 motor. The heads on the 73 will breathe far better than the 80's motor. Chances are the 73 heads might be a preferred casting, ...781 or ...049 . /forums/images/graemlins/thumb.gif
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Might not be a 4bolt. My 73 come from a 3/4ton. But it did have a steel crank. /forums/images/graemlins/thumb.gif It is now a 4 bolt. I would get the 73 because of the better heads. Not sure if the casting of the block is any better.
  4. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I'll be damned, I have never seen/owned a 2 bolt fat-block. Guess I am lucky that way. /forums/images/graemlins/wink.gif On the other hand, haven't seen/owned one that came with a steel crank, either. /forums/images/graemlins/crazy.gif
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I agree, the 73 is the way to go. The blocks are thicker and the heads are better. I have seen several 2 bolt blocks. I wouldn't be afraid of a 2 bolt block. if your gonna do a mild build up.
  6. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I would say you are REAL lucky! I've got 3 454's and only 1 is 4 bolt. <font color="orange"> TARussell </font> had 7 at one point and all but 1 were 2 bolt blocks.
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I'll put in a vote for the chance of the 1973 heads being of a good casting ( 049/781 ). Any 454 block is worth getting if it is buildable and the right price , but the older heads make so much more usable power from idle on up.There are a lot of descent castings but the 049/781's are the top choice in the factory oval port world.
    BTW Nvrenuf has been turning his present BBC up to 7200 RPM ( MSD rev limiter )and keeping it there at the mud bogs for years and it is only a 2 bolt main block. Spend the money on QUALITY machine work and get the rotating assy. balanced and run what Ya' got unless you are going to be making beyond 600 HP - than you will need better parts.
