Big block guys...how big is your air filter???
Discussion in 'The Garage' started by big pappa b, Sep 21, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just looking at some K&N filters. Found a 14x3 for a good price but was thinking 14x4 maybe..
    anyone??
  2. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    I have a 14" x 6" on mine. With the proper base & body lift it fit rather nicely. Too much filter never hurts.
    On a budget, 2 AC filters (P/N A212CW if I remember correctly)stacked also works.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    actually I read an article where they tested filter sizes, I think out of all they tested something like a 14x3 did the best, even vs no air filter. I'm sure that would change with motors.
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I run a 5" element in a stock air cleaner. The empty air cleaner flows the maximum a bigblock Quadrajet can at 1.5" of mercury. When you stick an element in the air cleaner the airflow is the same.
    The nice thing about this air cleaner is that it drops down around the carb. This allows the water you suck in to sit in the air cleaner base instead of splashing on the element. And even if it does get on the element it doesn't matter because the element is a lot bigger than you'll ever need. Wet elements don't flow air very well.
    PS: get rid of the charcoal thing on the air cleaner. It comes off pretty easy with a chisel.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I sure wish my stock air cleaner would fit on an Edelbrock carb. I've still got it, but it won't fit!!
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    dont need that poop eh? I oughta trash mine from my 85.. never even thought about pulling it, even tho I see it every time i check the air filter. /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
    j
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I bet the K&N 14x3 with the filter top would be more than enough! /forums/images/graemlins/thumb.gif
  8. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Nope, ain't need none of that excrement. Mine smelled like gas something fierce and it only sits like 1" away from the lid anyway. Save the screen around the charcoal though, it might come in handy for something someday.
    Those air cleaners are so tall I've been contemplating putting an air horn inside the air cleaner. If I could find an air horn I'd do it. All you need is 1.75" between it and the lid....
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I ripped my charcoal thing out a long time ago. I figured it just kills airflow, so I ditched it. I have a stock 85 air cleaner assembly like the pic and I am using the replacement filter from K&N. I am going to cut away part of my cleaner housing and add another air intake port that has tube to the other side of the rad. support so I can double my possible air intake. Should look cool too with dual pickup lines running to the cleaner. /forums/images/graemlins/thumb.gif
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, I may have to go with the toby-style bean pot air cleaner housing. I wanna nice big single 4" intake that I can attach to either the cold air intake behind the grille or to the azz end of some snorkle tubing. The cheesy little oval shaped intake on my factory 85 housing just looks pathetic and since long snorkel hoses might restrict airflow, I'd like to run a larger size tube. not to mention that tobys bean pot looks pretty bling bling... /forums/images/graemlins/grin.gif
    j
