Big Block heads Rectangular or Oval
Discussion in 'The Garage' started by kgblazerfive, Nov 28, 2005.
  1. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    If my exhaust is a square hole does that mean I have Rectangular port heads. I'm not in the mood to pull a valve cover to get the # so I was checking to see if anybody know's. The round headers that I bought won't fit the square exhaust ports so look in the sale forunm soon for them.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I have seen heads with all 3 intake port types (rect, oval, round) but I don't recall they're being a shape difference between the exhaust ports. :thinking:
    However, if the heads are newer than ~'75 (and they're not from a marine engine) you can bet they're the small round 'peanut' ports. :(
  3. Lonnie P
    Lonnie P Registered Member
    Feb 7, 2005
    28
    Pittsburgh, PA
    The rectangle/oval port refers to the intake ports.
    Most common big block heads have a square shaped exhaust port, athough round & "D" ports do exist. Your headers, as do most smaller tube truck style headers are round. You probably have 1-3/4" tubes. These will work fine on your vehicle. Do not worry about the mismatch. Just buy small diameter round port header gasket. I ran the 1-3/4" Hedmans on mine (like you are describing) with no problems.
  4. kgblazerfive
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    It doesn't appear to me that they will even match up so I put the manifolds back on, with new gaskets. The round is way small.
  5. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    nope i got a 78 1/2 ton burban with 10k tow package . it has large oval non emisions 454 in it.
    and for ports go oval for bottom end power.
  6. u2slow
    May 9, 2001
    2,217
    BC Canada
    Lucky dog. :waytogo: Certainly the exception and not the rule. :o
  7. sweetk30
    Nov 1, 2004
    25,548
    543
    yep drove the 454 a/c cruise and 400 turbo tranny home for 600 bucks. ha ha
