big block pulleys
Discussion in 'The Garage' started by fatbob, Aug 8, 2003.
  1. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    A friend had the pulley come off the harmonic balancer, break the water pump shaft, and send the fan into the radiator on his 454.He can get another water pump and radiator easy enough but he can't find the pulleys. We looked through 2 junk yards but couldn't find another 454 but some 350's had pulleys that look close. Any big block guys out there know if they will fit? /forums/images/graemlins/ears.gif
    thanks
    Bob
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The real main difference between SBC and BBC pulley's are the center hole for the centering/locating point. BBC's use a much larger centering/locating area than a SBC.
  3. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    So do you think it would fit if we drilled the center larger or would the bolt holes be off a little also?
    thanks
    Bob
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    No, the center is actually sticking out into the balancer, as a guide/center to center the pulley. Your best bet is to go to a Chevy Dealer, and just buy new, straight pulley's from the get go. Their cheap! it's the bracket's for A.C., Alt, an P.S. that they really nail you for. /forums/images/graemlins/grin.gif
  5. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    The GM dealer has priced over $100 so that why we're looking for a cheaper scource.
    Now for the water pump pulley, are THEY the same?
    Thanks for the replies
    Bob
