big block question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Jimmy, May 23, 2003.
  1. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Hello,
    I'm looking at repowering my K5 with a 427. I'm currently running a 350.My 700r4 was rebuilt about a year ago with a new stock torque converter. Will a big block require a different torque converter or will I be ok with the one I have? Thanks.
    John
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Dude, unless you had the 700 SUPER rebuilt, don't put it behind a BBC...you will toast it...If you are hell-bent on using the POS 700r4 behind a Big Block the stock converter will work, although I gernerally like a slightly higer stall speed...
    Chris
  3. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    700r4 & BB NO problem... Butttt... Need to replace some parts, about $700, and you will need a trans with a 30 spline input shaft...the 27 wont do.. will wind out of the drive shell...
    see:
    http://www.kdsperformance.com/kdsperformance/
    and also
    http://www.bowtieoverdrives.com/
    Usual parts, front pump with more vanes, bigger servo, bigger presure relief valve and boost valve... and the most expensive ($300), input shaft and drive shell set...
    Add master rebuild kit, with high performace band, and a vb reprogramming kit...
    Expensive, but WELL worth it...
    Just be VERY carful of the TV adjustment.. critical with a 700r4
    have done 4, one is in my 1978 K20, behind a mildly modified 1989 454.. Picked up nearly 8mpg over a TH400 with a wide ratio 2.75 first gear and 2200rpm converter
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
