BIG Block Swap from donor, what do I need???
Discussion in 'The Garage' started by 86haubs, Jan 8, 2007.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    Well I came across a free 77 2wd with a fresh 454. I am gonna put the engine in my burb, what exactly will I need? What problems will show up in the middle of the swap? I am sure it is a typical motor swap, but I just want to be sure.
    Will my 700r4 be alright? I know they are not great for handling tq, is shifts great, has about 60k on it.
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    It will bolt to the trans and engine mounts. I would put the burb radiator in when you do the swap. As long as the engine is complete with accessories just pull it complete and drop it in and go. The only other thing I can think of is the exhaust. It will have to be modified to work. As for the trans, it will work but isn't the best choice for a BBC in my oppinion.
  3. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I figured it would be just the exhaust. The only thing I plan on taking is like you said, the radiator. I can not think of any thing else I might need. Even though I will have the donor sitting right there I do not want to bounce back and forth pulling all kinds of nick-nack crap from it. I want a smooth swap.
    Will the long tube headers on te 454 cause a clearance issue with passenger rear shackle? I know they are barley touching with my 350.
  4. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    when i changed my 350 with the 454 the things i needed to change were the radiator, engine mounts and flywheel...
    the engine mounts for the 350 are smaller than the mounts for the 454. they wont be able to last for a long time with the heavy 454.
    the flywheel which was installed on my 350 was a small one and the engine needed a flywheel with an external balancer...
    i hope i didnt forget anything
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    alt p/s and a/c brackets are diffrent.
  6. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Good to know, I was almost certain that the ounts were the same, thanx for the heads up!
    SWEETK30-
    I am taking all accessories with the engine, so that is no issues!
  7. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    akinght-
    When you did your swap did you put long tubes on the BB? I am a little concerned with clearance issues since my SB LT's do hit the shackle on the right side now??
  8. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    i installed exhaust..
  9. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    If the 454 is from a two wheel drive, chances are the fuel pump is the "large" one, and will hit the engine crossmember. You'll need the short one from a K30 with a 454.
    Jimbo
  10. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    the one i swapped came from a 1991 2 wheel drive truck... and the pump is the big one... it fits fine...
