Big block TBI
Discussion in 'The Garage' started by dirty willy, Oct 15, 2004.
  1. dirty willy
    dirty willy Registered Member
    Apr 20, 2004
    6
    Ontario Canada
    Can anyone tell me if the wiring from a small block TBI will inter change with a big block TBI /forums/images/graemlins/confused.gif
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    It is essentially the same except for a couple of connectors and the length a a sensor wiring run or 2.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    depends on what year the SBC is and what year the BBC are
    If the BBC came from a truck that had a PCM, then NO the wiring harnesses are quite different. My 1987 SBC harness was pretty close to that of the 1992 BBC harness when I swapped it in my truck. I used my old harness and just had to swap a few connectors on the throttle body, since the sensors on the TB of the BBC had the newer style sensors. The PCM harness has wiring for the tranny and stuff like that.
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Oh, my BBC would've had a PCM but it was from a truck with a manual tranny so no PCM. I think 1991 or 1992 was the first year GM integrated PCM's to control the trannies
