Big block tranny/ small block tranny?
Discussion in 'The Garage' started by Thumper, Apr 27, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Im pretty sure I know the answer, but want to be sure.
    I have a smallblock in front of my 465... I may have a line on a 454... it will bolt in right? Do I need motor mounts? Any differences in clutch flywheel etc?
    Thanks.
    Mike
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    no need. Bolt it in and go.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    tranny will work fine. Pretty sure you can use the same motor mounts too but they do make some just for a BB. I believe the difference in in the height the motor sits..not sure. I have small black mounts on my 454 and it sits a little high. I need a little body lift for my valve cover to clear the brake booster
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the fly wheel is different. you will need one for an externally balanced 454 /forums/images/graemlins/waytogo.gif
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Yeah..that too /forums/images/graemlins/tongue.gif
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think the difference in motor mounts is the bolt pattern where it bolts to the crossmember.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only difference might be in the diameter of the clutch that was used from the factory. Some were smaller than others. With a big block twisting on it, I would swap the clutch and pressure plate to the largest size that will fit in the bell housing. /forums/images/graemlins/eek.gif Unless you find that you already have the big 'un. /forums/images/graemlins/cool.gif Either one will fit, but the larger diameter clutch has more holding power...
