big block
Discussion in 'The Garage' started by ilikemud, Jul 18, 2004.
  1. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    just curious, i found a 1985 gmc schoolbus with a 454 and 5 speed manual trans... i know that the motor is a low compression tall deck motor but is she a torque monster?? wanted to know if this would be a wise investment???
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    GM never made a factory installed 454 tall deck engine. You could however buy an aftermarket tall deck block and build it. The engine is most likely a 427 tall deck and they are good starting points for a large displacement engine build.
    Like they say,
    "no replacement for displacement"
    "when in doubt, bore it out"
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep, you could build a Big inch motor like this [​IMG]
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    427" and 366" tall deck motors are torque monsters... If the price is right, go for it ....
    Chris
  5. ilikemud
    May 22, 2003
    111
    The Farmhouse, NJ
    sorry it took me so long to respond, i was told it was a tall deck motor may be mistaken, cause it it a 7.4L = 454ci. i guess than what id like to know is will she bolt to my sm465? and will parts be interchangable between other 454s? and or any othe problems i may encounter thanks.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Chevy 90 degree V-8's and V-6's from the begining of time with the small block to the current LS1 style small block , including small , big , or w-headed , use the same bellhousing pattern . It will sit right in your truck . You just need the accesory brackets and other sundries to complete the install , like radiator , flexplate/flywheel is correct , etc. /forums/images/graemlins/k5.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If for some odd reason it is some kind of aftermarket tall deck block the distributor is special for it only.
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Only issue I can see is that it is probably high mileage. Are you planning to rebuild it or hoping to run it as is for awhile? Also whether or not its a good investment depends on what you are paying for the bus.
