big boom sound and the 14 bolt died
Discussion in 'The Garage' started by sidslc, Aug 6, 2004.
  1. sidslc
    sidslc Registered Member
    May 27, 2002
    96
    slc ut
    I was climing a rock face at little moab out side of salt lake and Boooom my whole blazer jumped> I looked back and nothen but 80-90w inside the bead lock. I pulled down(while the left rear made some nasty sounds and found that the flange had a new window in the center. I tried to pull the shaft out but it mushroomed out and split the spindel on the housing so I guess that it is time to salvage the detroit and get a new housing and start over.
    look at the pics in the link
    later sid
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Cool Carnage /forums/images/graemlins/waytogo.gif
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Weren't you on the cover of 4 Wheel and Offroad? Or was it Four WHeeler...so hard to recall /forums/images/graemlins/thinking.gif
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Petersen's if i recall correctly..... /forums/images/graemlins/whistling.gif
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Did you grind the nub off the face of the flange? I dont know if those are aftermarket or stock shafts, but I've never seen a stock shaft without the nubs. If you did grind it, you think that could have weakened it?
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    How/Where did you buy/make those spring perches?? Those are awesome, BTW you shop is awesome, where do you work at??
  8. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Quality breakage! /forums/images/graemlins/waytogo.gif
    Nice trailer, who makes it? It's hard to tell but it's 8 lug, right?
  9. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Too bad your not closer. I'd buy that housing from you. Now you can cut the spindles off and get some D60 outers and convert it to rear steer.
  10. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  11. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    that's what i'm thinking.. /forums/images/graemlins/dunno.gif
  12. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
  13. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Damn dude, that sucks /forums/images/graemlins/frown.gif
    I'm curious to what this set up this is...
    Another Steering Stabilizer?
    Linky no worky. /forums/images/graemlins/crazy.gif
  14. BOWTIE
    Dec 28, 2000
    2,018
  15. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    That's quality breakage...
    I wanna know about that trailer, I dig the drive-over fenders. Is the whole thing custom built or did you just have the fenders added on?
  16. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Wow that looks really familiar!
    Mine:
  17. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    ouch! nice carnage
  18. sidslc
    May 27, 2002
    96
    slc ut
    Yes I did grind the nubbs off and faced the flange on a lathe. If you look close thoes nubes are for a lathe to spin the shafts on when they are making them. The shaft has a centering pilot at each end also. and paul(blue blaze) you can blow me . Yes that is a coustom built trailer made so I can drive over the fenderwells. That trailer is rated at 14k lbs but unfortinatley it weighs 4K lbs.
  19. afroman006
    Aug 21, 2002
    2,876
    I always thought the nubbies were for grabbing with vice-grips when you were pulling the shafts out. /forums/images/graemlins/dunno.gif /forums/images/graemlins/histerical.gif
  20. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    /forums/images/graemlins/smirk.gif
