big carb,stock cam
Discussion in 'The Garage' started by chulisohombre, Jun 10, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i have a 350 with elelbrock intake 76 corvette heads with 2.02 intake valves.crane roller rockers with 1.6 lift.the question is:i have a holly 750 double pumper carb,will this be too much fuel for the setup i have without a cam?or will i get a little more horses and it should run better?thanx for any responses i get!!
  2. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    Re: big carb,no cam
    I went with about the same setup on my truck. Everybody around here said it would be fine with a 750 but it just poured too much fuel to the engine. I ended up going with a 600 and it runs perfect!
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Re: big carb,no cam
    What opens your valves if you don't have a cam in the motor? Or are you asking if that combo will work with the stock cam? /forums/images/icons/confused.gif /forums/images/icons/laugh.gif
