Big Deal or Not?
Discussion in 'The Garage' started by BigCountryx, Jul 13, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    When cutting the perches off my 1 Ton 14ff, I gouged the axle tube a little. The deepest part of the gouge is a little less the 1/8" and it curves out to nothing (due to the 4.5" grinder w/ cutoff that I was using. Should I grind it into a bevel (w/o going any deeper) and pass a bead on it, then grind back smooth or what?:doah:
  2. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Yes, grind it neat and then run a nice bead and grind it clean. :)
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Not a big deal, but I would prep it and weld it back flush. Return it to like original condition.
    John
  4. sweetk30
    Nov 1, 2004
    25,537
    535
    horseheads , ny 14845
    tube wall is 0.5" thick.:wink1:
  5. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    thank you for posting , i also have a 1-ton 14bff ..now i know i need to be very careful :rolleyes: ..but my angle grinder has adjustable speed...
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I did the same thing and forgot to fix two of the little cuts and have never had a problem.
