big engine trouble
Discussion in 'The Garage' started by adamforsythe, Jul 26, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Well a few months ago I pulled my engine to put chrome and paint on it. Well I got it back in the truck and I have been playing around with it ...hooking this up hooking that up, etc. Well a few days ago I put carb cleaner in the gas tank for the hell of it. Then yesterday I started the truck up to see how she ran. The engine rocks. But then it started to ping really bad I have no idea what is going on. I moved the dizzy around but nothing really happens. It just started to do it. Now it is hard to start the truck up.
    What is going on? This is a new engine in my book. There is only 10,000-15,000 miles on it. I am the only one that has owned the engine.
    Adam
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    did you replace you fuel filter, hoses. fuel pressure,mabey put premium down the intake? why did you put that in your tank???????
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hey the only mods I did to the fuel system was a edelbrock fuel filter that I installed at the first of this year. I did not put a lot of the carb cleaner in the tank. There was only about 1/3 of the bottel left.
    The engine shakes like a S.O.B in fact the whole truck shacked now. There is a lot of pinging going on in the engine. It sounds like the engine is camed with the biggest cam that can be put in a 350.
    Adam
  4. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Shake, rattle, and roll
    Did you check the plugs? Maybe something got through the filter and fouled the plugs...I know I have had 2 plugs over the last 8 months foul due to me needing to do a valve job and my truck runs like butt....like a huge miss. Just a thought...
  5. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Drain the tank, carb and fuel lines completely........
    refill the tank fire the engine and don't do that again.
    The ONLY thing you wanna pour in the tank or run thru the carb is gasoline........ :bow:
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I am going to go through the whole Ignition system today. I have a felling that a few of my plug wires are shot.
    Adam
  7. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    Dirty fuel
    Was it a full tank of gas with just 1/3 of cleaner? I have heard that the stuff you put in the gas tank does a great job of cleaning of junk from the walls of the tank and sends crap through the fuel pump (sometimes ruining it) then cloggs up the fuel filter. Some particles can even get into the engine. I would start with pulling the fuel filter to see if that is the case. From what the engine is doing, you could have some clogged jets or fouled plugs. Also check the basics. Is the engine getting fuel? Spark?
    Good Luck
