Big hub Little hub.....
Discussion in 'The Garage' started by jjlaughner, Jun 30, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK, I have several pieces and parts in the garage. I have a D44 4.10 with flat tops and 8lug big hubs (with the big warn lockouts), also have 8lug little hubs (warn lockouts), I need to swap onto my little hub 6lug with MM lockouts. Eitherway I'll have Warn lockouts, but is there a difference between the big hub and little hub bearings, lockouts, which is stonger, do both use the same stub shafts? Any benifit to using one or the other? they (including the flatops) will be going onto a 10bolt housing with 5.13's... /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    to make things easier, call the little hubs INTERNAL and the large hubs EXTERNAL.
    the external warn hubs arent worth much. although they are slightly better then the external OEM spicers that were known for weak plasitic caps
    the inner bearings are different between an External and Internal 8 lug wheel bearing hub. the outer bearings are the same.
    i am not sure if the Internal 6 lug and Internal 8 lug are the same bearings.
    also watch out, you may have 2 different styles of spindles also. keep the spindles with the wheel bearing hubs they came with.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    To add a little. The external hub spindles have a larger inner *shoulder* for the bearing to ride on. They will not work with internal set ups (such as 6 lug). All of the internal hubs I have seen are interchangeable between 8 and 6 lug. The stubs are the same in both. The 8 lug axle complete is a little wider from WMS to WMS (thicker rotor).
    hope that helps
