Big leaf spring shimming... What is the biggest you've seen or run?
Discussion in 'The Garage' started by sled_dog, Sep 23, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Well what is the biggest shim you have seen for sale or actually used? Think I am going to have to get some Zerorates made and angled... The S10 has quite a bit of angle on the old leaf springs. I haven't put a guage on it yet but I'm expecting 10* or more...
    Problem is this is just what I had to build. Didn't want to drop the front brackets anymore and hurt approach angle, and have to put the shackles where I have to put the shackles.
  2. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    Hi for now I am using 10deg shims on the back of my blazer. The problem I have found is that you have to use longer spring locating bolts since the head of the stock ones dont go all the way through the shim.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I use a 6* to flatten out the axle angle. If you are trying to angle one more than that upwards I think you will run into lubrication issues. Just reweld the perches.
  4. moturbopar
    Feb 9, 2005
    387
    mesa az
    OH yea, I used the 10 deg shim to flaten out my axle after the shackle flip.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm sorry guys, this is my FRONT axle. And it is mostly for Caster correction but of course also to flatten out pinion angle.
  6. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Earlier today I put in my 7 degree shims for the front end on the jimmy. It has 6 inch tuff country springs up front. I measured the angle and got 11 degrees so the 7 degree put me at 4 degrees like some other posts here said 4 to 6 degrees was good. Do a search quite a bit of info.
    I got my shims from JKW OffRoad. Good people, quick responses, good quality.
    Check www.jkwoffroad.com
    Something I didn't expect was it put my homemade hy steer tie rod into the springs so I have to shim that up so it doesnt hit the springs :(
  7. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    Imhaving JKW make me some zero rates for the front with a 14 degree taper. Will get my pinion angle better and will also move my axle froward 1.5". These are for my 85 s10 blazer SFA with d60 and stock 56" springs.
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Buddy has 12* in the front, he doesnt drive it on the street so who knows how his caster acts, but its fine on the trail.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Castor specs for our rigs is somewhere around 6*+, a little less won't hurt I'd say. I never have figured out why the stock spec is so much(when a lot of cars, even performance ones, are less then that). Thanks guys.
