Big Leak
Discussion in 'The Garage' started by 76blazerguy, Apr 17, 2005.
  1. 76blazerguy
    76blazerguy 1/2 ton status
    Nov 15, 2004
    125
    wichita, Kansas
    I have an oil leak and i cant find where its leaking from. Its a 76 if you couldnt guess from my name. Its a 350 and the leak is coming from what looks like maybe the block by the firewall or something around the back of the oil pan. Is this a common problem with these and how hard is this going to be to find and fix?
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    check the back of the intake , or the oil press sender, or the v/c gaskets. these are vary comon. if not them then most likly the rear main sel or the head gasket went bad. but i dont see many head gaskets going. i bet its one of the 3 listed first.
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Yeah i agree. My guess would have to be rear main(which would be the easyest to fix) but yeah could be valve covers, rear intake seal, OPSU, or even potenetialy the distributer gasket but i dought that. best bet is to clean evrything off on the back of the motor with a rag the best you can, then after it starts leaking again, crawl up and under it with a flash light and feel around till your hands get oily. good luck
