Big lift guys- who's had their knuckles turned/rotated?
Discussion in 'The Garage' started by COCHEV, Nov 16, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Big lift guys- who\'s had their knuckles turned/rotated?
    if you have, did you do it yourself or farm it out? price range? i've read that the hardest part of doing it yourself is getting the old knuckles off. grinder and a BFH. post up if you've done it and if it was worth it. thanks,
    jason
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Big lift guys- who\'s had their knuckles turned?
    Stupid question here, but what do you mean by having your knuckles turned /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The welds holding the knuckles to the axletubes are ground off and the knuckles are rotated to gain optimal pinion angle, then rewelded on.
  4. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    steering knuckles turned on the axle so you can point the pinion at the t case and still retain correct steering geometry. knew some guys here in town a few years back who did this. they where running 10"+ lifts and dana 60s with cross over and turned knuckles. seemed pretty slick.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Ah ok, I know what you mean know, just having an everyday brain fart and couldn't put 2 and 2 together /forums/images/graemlins/blush.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    Duh! everyone knows 2 and 2 is 5! sheesh!
  7. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I've always heard this was a good way to wreck pinion berings. The pinion is turned up too high to get proper lubrication. I've heard of (but never seen) sump pump set ups to pump the gear oil up to the pinion. Also, there are manufactures who make center sections which lube well at high angles ... but then you are getting into a whole new dif.
    Eric M.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    oh, ok... when someone says "i turned [insert part name here]" that says to me that they machined it like when you get rotors turned. cutting/rotating knuckles is what I'd call what ur talkin about.
    j
    ps: pad that post count... lol
  9. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    corrected /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    I first learned and heard about this method back in the mid-80's when I was a teenager. I was reading about Fly-N-Hi Offroad Center in Arizona doing the method what they call "cut and turn", which loosely translated is what it means. /forums/images/graemlins/thinking.gif
  11. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    It's also a trick when setting up a TTB diff up for the desert..................
  12. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Re: Big lift guys- who\'s had their knuckles turned/rotated?
    Don't forget about the spring perch that is cast into the diff housing. What would you do to fix that?
  13. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Shim it? /forums/images/graemlins/confused.gif
  14. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    i guess it would depend on if you wanted to go beyond what shims you could get. whats the biggest shim they sell? 4 degrees? 6?
  15. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    AZ-kickin sells 8-degree Zerorates
  16. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    If a shop does it they usually mill it down.
  17. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    OK guys, I've done allthat you talked about in this thread. On my d44 closed knuckle I had the ball ends cut off , rotated the diff 12 degrees, ball ends welded back on, pumpkin perch ground off,(using a giant industrial belt sander, and new perches welded back on. made anew steering knuckle to fit the right side to accept crossover steering arm and replaced those tiny studs that held the spindle onwith the bolts from a d60. by the way also had a spool installed in it at the same time all for under 350.00 beat that. if you need info on who what and where let me know I'll pass it along <font color="green"> </font> /forums/images/graemlins/peace.gif
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    shimming is a problem on the cast pad that uses studs rather then ubolts
    as now the studs do not face the right way
    recently there were a couple of bandaid spring plate designs on this site to help a few degrees of shim
    the correct way involves moving the studs to the new angle
  19. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    your really gonna mess up the caster on that axle if you do use just the shims /forums/images/graemlins/grind.gif
  20. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    I also saw guy who had flanges welded into the axle tube so that he could change the amount of caster depending on the /forums/images/graemlins/hack.gif amount of lift he was running
