Big lift on a 1990 Suburban
Discussion in 'The Garage' started by KingSuburban, Mar 12, 2006.
  1. KingSuburban
    KingSuburban Registered Member
    Sep 30, 2002
    7
    Jamestown, NY
    I have a 1990 Suburban I have rebuilt with a 6" SkyJacker lift and a 3" body lift to fit the 38" TSL Radials, you can see the build-up on my web site www.BURBEN.com
    I have a few questions I feel this site will be able to help with.
    I am swapping in the 1-ton running gear from my 84 K30 Plow Truck "Rusty"
    1) Is there anything special I need to look out for in swapping these in? Will they bolt up with my current U-bolts?
    2) I have the 12" front Superlift springs and will be installing these at this time too, what is the best way to set up the cross over steering? I have a 84 3/4-ton 2wd steering box.
    3) I saw pictures of the echobit flips but am concerned with how they keep the shackle from rotating back and forth? Does any one have any other pictures of them installed?
    4) I have seen multiple setups of the front shackle drops, is there one philosophy that is better than others?
    I would like to clear 49's and safely drive it.
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    This guy's in Alberta here somewhere, not sure where though. Those are 49" iroks. Daily drives it too.
  3. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    [​IMG] [​IMG] Very nice!
  4. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    this is my drop hangers, and while it got me in the air it was more of a headache than anything it dont steer very well with push and pull steering, and the driveline angle in the front is a mile off
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  6. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    flame me i deserve it, but it has never hit pavement like that, and 12" springs are on there way with stock bracket hangers
  7. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    I wouldnt do more than 12"s. Its just too much. My burb is on 12" springs and I managed to keep normal driveshafts in it and have been driving it to work 27 miles one way and back everyday. The way I see it is 12" is the cutoff. If you go much higher than that then your just asking for all kinds of headaches and have to fab up all this crap. Its just more headache and more down time. When you can just do a body lift (yeah i know no one wants them) and be done with it in like 3-4 hours. Then instead of fabbing critical parts to your suspension all you have to do is raise your bumpers to match and hide the gap in the rear.
    I'm on 12" springs & 3" body. I'm kinda happy that I was talked out of doing all suspension. That way I could keep normal driveshafts in it incase something breaks and to save $$$. Plus if this thing were any bigger I literally could not get in it.
    http://i2.tinypic.com/ravsbr.jpg
    Here's an old one. Thats my bro in the pic he's like 6'3"
    For some reason these pics dont wanna work right..
  8. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Welcome to the site King Suburban This info is on the 1990 suburban that I used to own. The new owner has installed 49" IROKS with the lift I had.
    12" Springs are do able for a daily driver but it's getting all the other parts to work, I've got a Suburban on 12" front springs, 6" rear, 4" shackle flip & 1" zero rate blocks w/ 1" push to recenter the rear axle, the front axle has a 7 degree shims with a 1" push also pushing the front axle forward for more tire clearance and rolling it 7 degree's for a better pinion angle. The driveshafts are where you can't cut corners, I have a 1410 size front 80 degree cv w/ 1410 at the front D60 as well, no binding of any sort, the rear is a 1350 series w/ 1350 at the 14-bolt, because it's on a suburban the rear is easy but still needs a cv, both my driveshaft came from Jess at Highangle Driveline, not cheap by any means but you get what you pay for. On 44" boggers my suburban cadillac's down the road, it can be done but you've got to spend the bucks.... I've built several trucks that big and if you need any help email me at offroad@cableone.
  9. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    KingSuburban,
    How much are you going to be wanting for that 6" lift kit?
    thanks,
    James
  10. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,014
    614
    Pueblo, CO
    I've had my echobit flips on for a year now. Pounded the snot out of them too. No movement what so ever on the flip brackets. Mine were really tight going on the stock hanger in the first place. One thing you don't se is the shape of the backside of the bracket. It is different than the outside and kind of nestles in the backside of the stock hanger to help it lock in. even still, one could put a couple of tack welds on it if they were really concerned about it moving. Mine hasn't.
    Good luck finding them if you don't have them. Check out the ORD, DIY4x or Sky versions to replace the stock hanger completely.
  11. KingSuburban
    Sep 30, 2002
    7
    Jamestown, NY
    I am going to put it on my K30 axle donor truck.
  12. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    12" lift... that gonna be a big truck....
    I had 12" lift and 3" body and before I got it done NJ changed their lift laws :crazy:
    so now I am down to about 8" total lift... and 40" hawgs (38.8 on 12" wide rims) to be street legal....
    now my truck isnt as big as it used to be but tell ya what... im having trouble fitting in the trails... and not width wise... height wise... I hit my kc's on branches... but they are broke anyway... but I even tag my windshield on branches... :doah:
    couldnt imagine being as big as I was.... hell I was even going on rockwells and 53's!!!!! :bow:
