Big problem!!!!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Apr 10, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Came out today to my carport and my 5 little eager helpers from up and down the road were drumming with my pushrods. Now none of them are in order. What are my options here? New pushrods? new lifters? Its on my new 350 that I am putting in. I took the heads off to get the valve seals done. I have to try to keep this as cheap as possible.
    On another note
    will 307 exhaust manifolds fit a 350??
    Which kind of carb should I use q-jet or edelbrock?
    Should I put electric fans on or should I keep the regular one?
    thanks for all the input
    Nathan
  2. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    I don`t think the push rods matter, just the lifters. For the cheap route, I would go with the Q-jet and a regular fan.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks
    If i did go with electric and picked some up from a junkyard how big would they need to be/
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    need to find out which one has the most cfm and get that one. Sometimes a smaller one has more cfm than a large one.
    John
  5. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Drumming? Hmmm... If there are any scratches, dings, or dents on the pushrod ends, replace them. Factory replacements are cheap.
  6. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    or bent! roll them on a flat table to be sure.
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i checked the pushrods and they are cool. i guess i will polish them up with the biffing wheel and put em back.
    what does CFM on a barb mean??
    thanks again for all the help
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    CFM...Cubic feet per minute The amount of air that goes threw it Most are around 650...
  9. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    if the exhaust manifolds are ramhorns they will work on your 350
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    cool thanks again for the help
    nathan
  11. 72gmc-burb
    72gmc-burb Registered Member
    Oct 22, 2001
    14
    Colorado
    Lifters are the most important, but I would still go to checker or etc. and get new push rods (cheap insurance). You may also want to look at your rockers closely to check for pitting and side wear. Good luck.
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ill go ahead and swap them to be safe
    thanks
    nathan
