big small block
Discussion in 'The Garage' started by blazin_blazer, Oct 4, 2005.
  1. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    what is the combination of parts people are using to build a small block with 427 cubic inches? i think i want to build me a mild version of this engine. as in compression to run pump fuel and cam that has fair/slightly rough idle.
  2. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Well, to start off with, you need to get the block to swallow a 4.00-inch stroke crank (not sure who makes small-block cranks this big) and that means grinding the bottom of the cylinders, the sides of the pan rails, and probably a few other places for connecting rod clearance, and then the cylinders have to be bored out to 4.125-inches. That's all I can say for the moment, as I have not read that much about building small-blocks this big.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    About the same thing as turning a 350 into a 383, except with starting with a 400 block....
    http://strokermotor.com/
    I can give you a few more sources for info later tonight....
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    To make a small block that big you are probley going to have to use a after market block. The after market blocks allow for a much larger pistion and crank then a stock block. The largest i have heard of for a small block is 472 Cubic inches :eek1:
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Get a block from world castings they make a 427 small block as well as a 454 small block :D
    Ira
  6. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
