"BIG" small block
Discussion in 'The Garage' started by tiger9297, Oct 10, 2005.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I was watching the Horsepower TV marathon yesterday and on one episode they built a 472 SBC. The block they used was not a standard block though. It had a raised deck and a few other mods I think, but being relatively inexperienced at this I was wondering what is the biggest ci. you can get out of a standard 350 block? I've kicked around a 383, but just wondering what else was out there.
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  3. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I guess I was thinking about what could be built starting out w/ a 350 block. I would not want to use a 400 block. Too many issues there.
  4. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    391 CUBIC INCHES IS ALMOST THE MAX YOU CAN GET FROM A 350 BLOCK. i CURRENTLY HAVE ONE OF THOSE.
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Mines 388. A 350 bored .060 with the stroker crank (or 400 crank machined to fit). I think thats it. Next one I build I'm gonna start with a 400 block. Maybe build a 415 or 420. 400's are fine if you address the cooling areas. Ive seen many 400 motors in the 410 -420 cube range that make lots of power and work fine. Remember theres no replacement for displacement!! :bow:
  6. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I think about the max you can safely get out of a 350 block is .090 over, then stroke it w/ a 400 crank. the guy with 391 sounds right about right for a 400 crank at .090. I personally wouldn't go any more than .060 on a 350 block....
    If you want any more than that and you'd have to step up to a 400 block.
    Mike
