Big Tires= Big Fuel Consumption????????
Discussion in 'The Garage' started by 1985K20, Mar 17, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Ok i know lots of yas are running big blocks and diesels in your rigs...here's my question!:Is bigger cubic inch engines absorbing the crazy fuel milleage increase with big tires(33's and over)???
    friend of mine told he seen very little difference with small or big tires with a 6.2 diesel...
    I know my little 305 burns just about twice as much when i put my 35's on, but buddy's telling me he sees no difference small or big tires with a 366 BB..
    Are they bull$h*tt*ng me or is it true?
    :thinking:
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    I get 16.5 mpg on the freeway pushing 39.5" TSL's with my 6.2. That's without an overdrive, and from what I have heard from other 6.2 owners that are turning about the same rpm's as I do their mileage is about the same...maybe slightly better. The 6.2 doesn't really seem to care about the larger tires, just the actual rpm's. If I could get the rpm's down I could pick up a few mpg.
    Rene
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i always say its in the gearing!!!
  4. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    Im running 39.5s with 4.10 gears and a stock 350 with no noticable change in mpg in my 78 suburban
  5. dyeager535
    26,977
    My dads K20 is running a 454 with 33's, and it gets the same in the city as it did with the 350. Freeway is about 1-2MPG less. 4.10 gears, gear vendor overdrive.
    Lots of factors, contact patch, tire diameter, vehicle height, etc.
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    With my 6.2, i dont notice much difference between the 33" radials and the Q78's. Its still slow as crap and gets at or over 20 mpg depending on how i drive it.
  7. r_pogo
    r_pogo Registered Member
    Mar 15, 2005
    23
    Azrizona
    Tire Pressure & MPG
    On a road trip it might help increasing the tire pressure a bit.
    On several cars/trucks I've owned I have had a 1-2 mpg increases by bumping up the pressure 4-5 or so psi over the sticker while still under the maximum indicated on the side of the tire. This also make them run a bit cooler and wears more on the center to compensate for wear on the edges that happens in all the city dirving.
  8. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    i just went from 33's and stock 3.42 gears, to 35's and 4.10's... man what a difference!! more power, better mileage, better everything!!! and thats with the 6.5L, it feels alive again!!! :p: probably averaging around 16-17mpg..
  9. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    i wonder how i'm gonna feel after this:
    from 32's & 2:73 to hm have not decided what tires yet but 4:56 gearing :D :D
    problably gonna feel like i'm still in 1st gear!!!
  10. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I went from 33x12.50s(measured out at about 32) and a 350tbi, went to a 496mpfi and 35x14.50's, and my mileage went from 8 to 10-11.
  11. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    exact same thing here
  12. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    454/TH400/4.10 diffs/39.5's I get 10-11mpg hwy (best at about 2200rpm) and 7-8mpg in town.
