Big tires, old school leaf springs, lotsa hard wheelin
Discussion in 'The Garage' started by FWP, May 8, 2006.
How often do you replace your leaf springs?
Poll closed Jun 7, 2006.
  1. 6 months
    1.4%
  2. 1 year
    5.8%
  3. 2 years
    5.8%
  4. 3 years
    2.9%
  5. Never
    69.6%
  6. This poll is Stoopid (insert subtitle)
    14.5%
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm curious if I'm in the minority, or it's normal. How often are you replacing them due to breakage or sag? If you reply, add your specs... ie. tire size, axles, spring type/ lift, wheelin style etc.
  2. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    never, cause im a web wheeler.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I killed my super soft stock 56" rears in a little over a years time. My front BDS have sagged but aren't causing problems yet. Then again I'm no 6:1 big dawg!!:haha:
  4. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Had to say within 6 mo.....Broke a set of RANCHO vomit.gif 4" front springs a few years back,while I was running 42's on a '73 3/4 ton.I mostly ran in the mud and the occasional trail.Broke the main leaf right behind the eye. Swapped them out for a set of Superlift springs and never looked back. I put the 6" ers on my K5,with a heavy 'ol piece of steel for a bumper and a 8274,no problems (so far)...
  5. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I have had my custom Deavers on for about 2 years now and still no sag:D.
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    My buddy did a SOA on his cj with waggy springs, and they are allready starting to bend and sag after one run, but man can they flex
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    It must be the dry weather making your springs brittle:doah:
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I voted never but I have only had them out once since I put them on. Furthermore the spring packs were already bent when I got them:D . I run 1 tons with 37 MTRs and Rock:D I also do not have any spring clamps on them and they drop out like crazy so it is prolly only a matter of time before I bust a leaf.
    Ira
  9. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    is there any danger/negative effects to removing the spring clamps?
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Once/year on the FunBuggy...
    Coils & coilovers would probably be better at lasting for our application. The twisting is what kills them...
    Marv
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I installed 4" Skyjacker softride springs on my truck back in '96 or '97. I wheeled if pretty hard for years, including a couple years of being on 1-tons, dual lockers, 38" tires, front winch, and a heavy diesel engine before putting a small bend in the driver's side main leaf. Replaced them with 4" Tuff-Country HD's over a year ago and no problems so far.
  12. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I am using superlift springs on my truck. On my sami I replaced springs once a year mostly because of axlewrap in the rear. Fixed the axle wrap and didn't let the front springs go negative arch and they were fine after that. Front springs on my blazer are needing replaced if I had the money. It is from them going negative arch. Rear springs are showing their age. If I had the money I would replace them all the way around but I don't. BTW I have 40" iroks 1 tons 4.56 gears a 203 and a small block the springs are superlift rear springs from a 94 Dodge
  13. sandawgk5
    Oct 28, 2003
    6,881
    Only thing is possibly the spring can fan out if dropped out. But worse with no clamps the spring can drop way out and possibly break the main leaf.
    Ira
  14. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I haven't had to change them yet, but a friend of mine gave me a one off set of spring savers he built for his rig. I plan on installing them in the rear here in the next few months. They prevent spring twisting and are not recommended for street driving. Here are a few pic's:D
  15. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    I did some like that for my zuk but I put a spacer thing on them I could pull on and off so I could take them off for off road. On the road it definatly made the body roll worse. It also definately helped the springs live longer
  16. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    i put my 3inch lift in today, and when i was taking the rear apart to put my lift blocks in, my over load spring, and my helper spring where broke in half. yay for me, now ive got new springs in it.
  17. dhilgenberg
    dhilgenberg Registered Member
    May 18, 2005
    11
    Antioch, IL
    Never replaced them but rears sag a little dont cause any problems its a little bumpy even with my new rs 5000s but no big deal in the mud
  18. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I havent replaced mine (though i havent wheeled it in over a year) but the rears (ford 56's) both have been bent over backward plenty of times---the bushings do need replacement the front tuff country 6" held up well also. I think i had about4 years pretty hard wheelin.
    all being run on your 42's:doah: and springer's odd ball ORD/springer flip:D
  19. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran my stock springs for a long time. Then I started wheeling with you guys and they died. I replaced them with 6" TC EZ Rides and I cut the overload down and removed the bottom leaf to lower the springs to match my 4" lift. The first run out I S'ed both rear springs. I have run them for awhile since but they need replaced. I am going to be installing the controversial "Springer" rear spring setup this summer. We all know that excess droop is overrated and that the Springer setup doesn't work. :D But what the hell I know a guy or two that has used it and it seemed ok to me.
    Harley
  20. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Not yet. I have been wheelin 4 inch skyjacker softride springs pretty hard for about 5 years now.
