big tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chrislk02, May 18, 2001.
  1. chrislk02
    chrislk02 Newbie
    May 18, 2001
    3
    i drive a 79 chevy blazer. we put a 4 inch suspencion lift and a 1 inch body luift(closer to 2 with the new bushings). we have also had the fenders cut back and the bushwacker fender flares put on. does any body think 38 15.50 tires are to big? if so, what could b done to make them fit?
  2. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    38's are probably pushing it a bit. You gotta have room for those meats to move around without rearranging your fenders. Do you have a buddy with tires around that size?
    Maybe you can test fit 'em. Or if you find a shop in the area that has em, sometimes they will let you test fit em. Otherwise it's quality time with the tape measure checking all the ways that tire can go. Good luck.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  3. 1big78k5
    1big78k5 Registered Member
    Apr 1, 2001
    92
    moosup, ct. usa
    I would have to say 36's are about the max for that amount of lift, if you want to be able to wheel it with out loosing your fenders or tearing up your tires.
    '78 K5 SB400, T350, NP203, 35" Swampers
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, on that truck with 4" you can run 35" with a little trimming. Some people go to 6” for 35s. I think cutouts (unless they are radical) will allow 36" or so depending on how flexy your suspension is. You might be able to run bigger tires by using bump stops to limit travel but I don't think I would go that route. I think 38s are going to be a little too much. Like the other post said, when you want to push the limit like that, the best thing is to find a way to actually test it on the truck. Make sure you test it with one wheel full stuffed and the other at full droop just to make sure.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  5. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I personally think 38's would kick some serious butt ! Have you seen pccorsmit (i think thats how you spell it) It has 2.5 inch lift and 39's ! I love the look !
    - SlyDog [​IMG]
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Sawzall it and it will come. All depends on how much off roading your rig does and flex...
    1987 Chevy K5 Blazer- 350 TBI
  7. yes! cut cut cut!!! big tires, low lift, cut cut cut! 38s would kick a$$. pete's rig should be an ispiration to us all to buy a new pack of sawsall blades and go to town! i plan to squeeze another inch or so out of my lift and go 38s when my 35s wear out.[​IMG]
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh yes! I totally agree on the cutting! [​IMG] However, he mentioned using 'Whackers" so his cutting option is limited. Not sure exactly how much room those flares provide but I don't think it will completely clear anything larger than 36, maybe 37. Of course, I could be wrong, those flares may provide more room than I thought...
    Bad Dog
