BigBlock 454 with Th350
Discussion in 'The Garage' started by aknight_sa, Apr 15, 2006.
  1. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    do they work normally together?? or would the 454 kill the th350 with time?
  2. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    The TH350 only reacts to what hp/torque is being directed it's way. I've got a buddy with a very mild 454/th350 combo in a very heavy Sub. that gets the heck wheeled out of it and has lasted a couple years, yes it has the appropriate coolers but that's a necessity for any auto.
    I'll bet there will be a lot of input on this , also a couple that will scream..Search..., but first more info. Is it a fire breathing big block or a low hp, easy running torque monster?
    Light or heavy rig?
    tow or play ?
    Jeff
  3. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Put a 350 behind a bombed (souped up) Cummins. Lots of torque. Use a Allison torque converter tho.
  4. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    up to now its a standard 1991 big block installed on a 81 Jimmy (also standard, no lifts) not planning on doing any mods, it will be a normal day to day car plus crusing in the dunes!!
  5. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Just be careful... sand has a way of blowing things up... since your constantly spinning the tires it heats up alot of things... especially the tranny. Just don't get too crazy.
  6. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    I run a TH350 behind my pretty much stock 454. I've been running this setup for about 6 - 8 months now with no issues but the truck is mostly a DD. I don't have a lot of confidence in it lasting long if I beat on it regularly though. When this one goes I'll put in a TH400, but I just don't want to swap transmissions unless I have to.
  7. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I talked to my local tranny guy when I was thinking about running a th350 behind a stout bbc. He said he could build the tranny so I wouldn't have any problems. Since then, the bbc still isn't done, but I changed my mind to go with a th400, but now I'm leaning towards a 4 speed:D
  8. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    With a stock BB im sure it will be fine. I have a 500 HP big block with a 2800 RPM Stall. And used the stock tranny cooler. Needless to say my BB only has 110 miles of break in and the TH350 ate sh*t. But notw im upgrading to a TH400 with a B n M tranny cooler. But yeah if your all stock you'll be fine. Only problem i had with it was the governer went out so you had to manually down shift. Hope it helps.
  9. aknight_sa
    Oct 14, 2005
    305
    Saudi Arabia
    my Jimmy is now running with the BB installed, i kind of like the power its giving me.. but when i give it a full throttle the car's body doesnt like it and shakes like an earthquacke it about to happen.. also, there is a bad smell which i cant really identify comes out when i give it a beat..
  10. Stump-a-holic
    Stump-a-holic Registered Member
    Mar 21, 2006
    29
    South Wales, NY
    I am running a some what built 468 with a built t350. I've owned the truck for 5 years and the guy I bought it from built it up this way. Other than blowing a line once Ive never had any problems with this combo. I mostly do deap mud and Im never kind to the forward-reverse action. I always figured it would go and I would upgrade to a 400 at that point but its seems to be holding on pretty good.
  11. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I personaly went through one a year for 4 years behind my stock 427 tall deck in my 72 blazer. I just pulled the last one apart to what happend and every shaft was broke. I was just drive down the highway when it went.
  12. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I had a 72 c10 2wd with a 454 and 350t, I had it rebuilt twice in one month. The first time it broke the second gear all to hell, The second time the front pump literally broke into about 5 or so pieces. Sold it not long after.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    drag cars do it all the time.
