Bigger master cylinder options? (searched)
Discussion in 'The Garage' started by 88K5Jimmy, Jul 14, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Right now I have the stock 1/2ton brake system, with disks in the front and drums in the rear. Would it be a worthwhile mod to upgrade the 1/2 ton master cylinder to a 3/4 or 1 ton? I don't want to do hydroboost or rear disks at the moment so all that stuff is out. Basically, do the internals of the 3/4 and 1 ton stuff push more fluid than the 1/2 ton stuff? Or are there any other options such as aftermarket master cylinder systems?
    Ross
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    one tons wont fit a stock half ton booster..we put a 3/4 ton on my buddies, combined with the rear disc setup on the 14b, it stops really well, of course the old master was leaking and all that crap so...
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    K30 booster and K30 M/C.
    both of yours will be tired, so a upgrade would be a good idea as preventive maintenance too.
  4. Grim-Reaper
    7,385
    Atlanta
    I have the stock 1/2 Autozone $17 rebuilt master on my truck with the AZ Kicking rear disc kit. Firm peddle and no problems stopping 35's even with 2,000 lb of trailer behind it that doesn't have brakes. .
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    If I was to replace my MC with a 3/4 ton, what year truck should I ask for? Somewhere in the 80's? What about replacing my stock MC and booster with a 1 ton MC and booster? What years should I ask for in that? Also, is there a larger piston or something inside the 3/4 and 1 ton stuff that makes them better? Will my brake lines fit the new MC either 3/4 or 1 ton?
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I put on a 3/4 ton MC and I just used the same year as my truck. I don't know if it is any better than the 1/2 ton, but it bolted up the same, lines all fit. The only difference I saw was that the reservoir size was larger. It was only like $17 so it wasn't a big investment either.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What is your goal in swapping MC's?
    Do you know that a larger bore MC will make braking harder?
    It will also make the peddle firmer and higher (when you stand on it)
    What is the bore on a 1/2-ton MC?
    What is the bore on a 3/4-ton MC?
    What is the bore on a 1-ton MC?
    Enough questions how about some answers...
    All '79 w/ 350 engine. Info from www.napaonline.com
    1/2-ton
    Bore Size: 1.12500''
    Line Thread Size: 9/16-18, 1/2-20
    3/4-ton
    Line Thread Size: 1/2-20, 9/16-18
    1-ton
    w/ Hydro-Boost
    Bore Size: 1.31250''
    w/ Vacuum Booster
    As you can see going to any other MC other than a hydro-boost will not do a thing for you.
  8. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
  9. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I was just trying to get a MC that would push more fluid. However, looks like without a bigger piston in the 3/4 and 1 ton stuff I'm not gonna gain very much. I think I have air in the MC or close to it cuase the brake light comes on and I have a crappy feeling peddle, real squishy and doesn't feel like the truck is going to stop. Probably just need to bleed the whole system again.
