bigger tires and the best gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PineyPower, Sep 25, 2001.
  1. PineyPower
    PineyPower Registered Member
    Jan 16, 2001
    52
    New Jeresy out in the pine barrens
    Is 2.73 gears ok for a set of 35in tires???
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    It maybe a slow start but good on gas. I have 32" with stock gears and hate it
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm running 307's with 33's and its slow off the start. The biggest gripe is that at freeway speeds it sits between 2nd and 3rd on my th350 trans with a stock stall converter and heats up the tranny fluid. 33's a 356's might be a better combo.
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That setup will work OK if you always drive down very steep hills. [​IMG] Getting to the top of the hills will not be much fun though. [​IMG] 2.73 is pretty far away from the optimum 4.11(without an overdrive trans) or 4.56 (with an overdrive trans) gears with those 35's.
  5. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Yeah, it would be a slow start, but it would be terrible on gas. The motor would alway's be lugging at a low rpm. The engine will run hot, and the timing would have to be retarded.
    Keep it simple
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    NO you should have atleast 4:11's with 35in tires 4:56's would be better and if you have a 700r4 4:88's would be best. if you runn2:73's with 35's you will over work the tranny and motor + you would have to have one hell of a motor to climb anything lol
    wheeling videoshttp://community.webshots.com/user/ssmith6333
