Bigger Tires
Discussion in '1936-Present Suburban' started by Irish Wake, Jan 25, 2007.
  1. Irish Wake
    Irish Wake Registered Member
    Jan 15, 2007
    44
    Georgia
    Can a larger size then 31 10.50 15 be mounted on the stock rims that came on a 1988 K5? I have 31 10.50 15 on there now but they look small up front, the truck is 100% stock now.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You can easily mount 32" tires on the stock rims, you might be able to fit 33" tires on the stock rims if your springs are not sagging or the truck is a 3/4 ton.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I fit 35's on stock rims , steel ralleys . and have seen it done on stock aluminum . The tires fit fine , the truck with no lift presents a problem :thumb:
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have put 38's on a stock rim, I was referring to the whole setup staying stock :rolleyes:
