Bigger tires
Discussion in 'Plains Region' started by crroy71, Jun 24, 2002.
  1. crroy71
    crroy71 Registered Member
    Jun 23, 2002
    38
    Mont Belvieu TX
    What is the biggest tire I can run without a lift, and without rubbing? 33's maybe?
    '86 K-5 all stock for now.
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    depends on what your doing...with 3" lift and 33's i can rub when im flexed out w/o a sway bar. on the street you can prob do 32 no prob.
  3. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    I've got 33's with no lift, but they're on the factory 8 inch rims. From what I've read if you go with 10 inch rims then you're gonna need a lift. All the fitment charts that I've seen say 2.5 inches or more.
  4. crroy71
    Jun 23, 2002
    38
    Mont Belvieu TX
    I will try the 33's, since they are going to be on factory rims for a little while. When I get my lift, I will go with wider wheels.
    Thanks,
  5. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    As long as you stay with the factory rims and keep the tires in the fender wells you should be ok. I have 10" rims and 33's with a 2.5" lift and they rub while flexing with the swaybar still attachted(SP?).
    James
