Biggest Lift before Steering mods.
Discussion in 'The Garage' started by FastFob, Sep 28, 2002.
  1. FastFob
    FastFob Registered Member
    May 25, 2002
    25
    East Bay San Francisco
    How high can you go before you need to modify the steering gear?
    What's out there in modifying the steering? Dropped Pitman arms? More powerful Power Steering unit? Crossover?
    Thanks!
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Even with just a 4" lift you need to replace the steering arm with a lifted steering arm.
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I've seen some people get away with a 4" without one, but it is more of an application issue. I have seen stock GM 3/4 ton trucks from the factory with a steering arm that falls somewhere between a stock and 4" arm, and those worked with a 4", and I have seen 4" lifted rigs with the stock arm work *OK* without steering mods. That said, to avoid bumpsteer and to keep your turning radius tolerable, steering corrections are necessary.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    mines got 4 inch with raised drag link.need one of those crossovers someday. /forums/images/icons/laugh.gif at least when i start wheeling for "Real".
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok so the steering arm..what about alignment and all that stuff?
  6. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    You can align your own rig, or take it to a shop. Alignment is pretty easy to do on these trucks. Do a search, someone did a write up (I think) on aligninment. I don't know exactly how to do it, so I will leave that recommendation to someone that has done it lately.
