Biggest size tires on stock K5?
Discussion in 'The Garage' started by AJMBLAZER, Mar 21, 2002.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    I know 31x10.5R15's came from the factory, but how big of a tire can I fit without a lift? When I get a K5 there isn't going to be much money left over to buy a lift yet, and I know whatever I get is going to need new tires (even if it has "good" tires on it/forums/images/icons/wink.gif), but I still want to get the biggest tires I can wedge under there.
    Thinking about the 1" ORD body lift and the 1" ORD zero rate add a leaf. Maybe a little trimming. Hell, maybe some Bushwacker cut outs right off the bat with some 33's.
    I'm thinking 32x11.5R15's if it's completely stock./forums/images/icons/cool.gif
    Who's actually done this? What fits, what hits?/forums/images/icons/tongue.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran 32's on my Jimmy when it was stock no rub. You can run 33's stock, but they will rub.
  3. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    ill say 33's if your springs are not too whooped. I had 33's in my stock blazer when i bought it, worked fine w/ no rub. i flexed it out a few times with no problem, but if i had disconected the swaybar i probably would have rubbed. (of course i had to go and buy 35's and cut up the fenders to fit them cause i couldnt wait for the lift......./forums/images/icons/smile.gif)
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> I would think no bigger than 32's !
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I'm running 33x12.5 on 15x8s. I can them to rub flexing hard.
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Get creative and put 35's under it. It can be done with 2" of lift like you described and some hacking. /forums/images/icons/smile.gif
  7. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Trim your fenders and get 35" tires. I have a front shackle lift(about 1") and a rear add-a-leaf(about 1") with 35" BFG mud tires. I bought it this way and the tires rubbed going into my driveway, so I trimmed the fenders and no more rubbing. Later I added the ORD 1" lift. If you have the K5 addiction you will end up wanting bigger tires. Going straight to 35" tires will make you smile./forums/images/icons/smile.gif
  8. Grim-Reaper
    7,385
    Atlanta
    I scrub 32's on all four corners with 4 inch front springs and a shackle flip /forums/images/icons/smile.gif Course my truck ramps 800's on a 25 deg ramp. Now where it rubs is on flats and on the inner wheel tubs on the rear. So no big deal.
    33's will fit stock if you trim the rear edge of the front fenders and leave the sway bar connected it will work.
    1 inch body lift and Zero rates on the front shifting the axle forward an inch will do pretty decent with 33's and some trimming. You can probably get away without the sway. Again they will probably scrub on the inner fender up between the bolts in the back but it's flat there so it's doable.
    On the rear I would put 2 inch blocks and try to find STEEL blocks with no wedge to them. 2 inches is well within what the stock drive shaft can handle and should run vibration free.
  9. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I have 32's and a couple front fenders that have a little bulge in them at the top because of the tire bottoming out in the wheel well.
    Mike
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    dont see why u couldnt fit 35s if you modified inner/outter fenders wherever they rubbed.
    J
  11. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    When we bought my 85 in '97 it had 33x12.50x15s on it and never rubbed and we did have the sway bar on. We kept them on there for a year until my dad gave it to me then it was taken back down to stock size.
  12. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    My 78 K5 is stock and I have 33x12.5s on 8 inch rims. The only time I rub is when there are huge icicles hanging on the from of the wells in front. I just kick off the ice. Other than that they don't rub at all and I think I could get away with larger without rubbing. Of course then they might rub a little if I ran over a log or something.
  13. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I stuffed 35" Boggers with no lift and some trimming. It wasn't pretty but it worked.
  14. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    35's are tempting, but I think it'd be better if I kept it closer to stock. 32's sound good. Not to mention the stock gearing is probably going to be 3.08 or 3.55, so 35's wouldn't play nice with those cogs./forums/images/icons/tongue.gif
    Thanks guys. I've got a set of 15x8's with like 3 and 7/8" of backspacing, that should help to keep the tires off the fenders./forums/images/icons/cool.gif
  15. ABO
    ABO Registered Member
    Jan 16, 2001
    77
    The Burgh
    Was Able to fit 33x12.5x15's with barely any rubbing on the drivers side. No Problem.
