biggest tire to fit stock k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyrulz420, Sep 7, 2000.
  1. chevyrulz420
    chevyrulz420 Newbie
    Sep 7, 2000
    can i fit 33 12.50 15 on a stock 82 k5 and if not what cutting is nessary.
  2. slodawg
    slodawg 1/2 ton status
    Apr 30, 2000
    190
    Southern Arkansas
    33's can be run but will rub with articulation. itll rub the drag link at the pitman arm at right hand lock. With factory wheels. 31's are the size to run if you dont want any big probs.
    <font color=blue>SLODAWG</font color=blue>
    http://www.slodawg.coloradok5.com
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I run 31x13.50's and yes they do rub a tiny bit when backing up at full articulation. They look good on stock.
    And Yes I know.... "Look out little boy".
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I ran 33s with no lift for about 5 months before I put my lift on and they didn't rub. It depends on the truck. there are some that will fit them and some that wont. If you dont know what will fit a good tire shop will usually test fit the tires on the truck for free. I know some rub with 31s but others can fit 33s. It must depend on the suspension or year or something. My advice is to have them test fitted first.
    90K5
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Nope,I think not I have a 2.5 inch lift with 33 swampers and a I still rub!
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Will also depend on wheel width, and tire brand. Had 33x12.50 on 8 1/2 inch wide wheels [bfg a/t tires]on my 89. Only rubbed at full lock to the right. But my 87 needed 2inch lift for 33's. No rubbing.
  7. bosifus
    bosifus Registered Member
    Jul 10, 2000
    29
    Tacoma, WA
    I had 33 in MT's on mine and it rubbed under hard turns and bad articulation and that was with the fenders notched out.
    I would stick with used 31's until you can afford or swap for a lift.Just my tew sense.
  8. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    33's on my 89, never rubbed.
    <font color=purple>delta9blazer</font color=purple>
