Biggest tire?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RIDNHIGH, Nov 11, 2001.
  1. RIDNHIGH
    RIDNHIGH Registered Member
    Nov 7, 2001
    26
    Bismarck, ND
    What is the biggest tire I could fit on a blazer with a 4" lift?
    OR even 4" with fender cut outs?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You can fit 35s with 4" lift, but they will rub with a soft lift. If you go rough country lift they will not rub, because it will pick a tire off the ground before if flexs. If you do cutouts you could get away with 36s on a soft lift or even 37s.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. RIDNHIGH
    Nov 7, 2001
    26
    Bismarck, ND
    Will i have to a pitman arm and lower transfer case with a 4".
    Or basically just longer brake lines and a whatnot?
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    4" steering arm, longer brake lines, and probably have to lower the t-case 1". Lowering the t-case is easy, ust use the spacers that are on top of the crossmember and put them between the crossmember and the frame. As for the steering arm is like $65.
  5. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Gotta disagree with you on the Rough Country DD. I have the Rough Country 4" all spring lift on mine with 33's and they will flex and the tires will rub.
    How big of a tire depends on what your wheeling needs are and how much you're willing to trim. Generally 4" and 33's but if you do cutouts you could get away with 36s maybe even 37s if you leave the sway bar hooked up.
    Scot in KC, MO
    Rough Country wont flex right? - <a target="_blank" href=http://coloradok5.com/gallery/albun29/aab>Pics</a>
    87 GMC 4" lift, 6 lug 14SF LockRite, 33s
  6. RIDNHIGH
    Nov 7, 2001
    26
    Bismarck, ND
    Well in that case i might as well stick with the 6" lift, if i have do the same modification with a 4".. Is there a 6" lift kit out there that comes with alot of the extra steering components needed to complete the lift with out buying everything seperatly?
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    How much you wanna cut out? Mine works good with the 39.5s on a 3" lift. Better buy a few extra sawzall blades, though.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    It must be an old setup becuase my buddy put a 4" lift rough country on his and the front doesnt move at all. The rear is blocks so it flexs. When we lift the front of his truck on the rack at work they dont come out at all. Rough country front spring rate is 604 lbs/in versus tuff countrys is 295 lbs/in.
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Also the rough country 4" isnt 4"s free arch on them are 3.48" Thats with no weight on them. Where as the tuff coutrys are 5.75" with no weight.
  10. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i disagree as well, my RC 4" was 2 months old and i could rub 35's, and i even had a 3" bodylift!! plus, the bottoms of the fenders were already pushed up a little from previous rubs before the lift and 33's.
    matter of fact, with major trimming, i still managed to hit the INNER fender where it was cut near the bolts. of course the other tire was way of the ground, so the full weight has on that side. i had 38.5's on too. thats still a long way to reach though.
    just my .02!![​IMG]
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  11. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    My old Rancho 4" fronts are supposed to be over 500 lbs/inch, and I stuffed my 35's into the fender a few times till I trimmed it. Rim offset has a lot of effect on whether or not the tires will hit the fender too.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  12. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Well I am just going from what ive seen. I knoy my truck rubbed like crazy down a trail, and my buddies didnt. We took the same line. I have the tuff country ez ride 4" lift with 35s on 9" wide wheels and 3 and 3/4" backspacing. My buddy has the rough country 4" lift with 35s on 12" wide wheels and 3 and 3/4" backspacing. Mybe they flex with alot of weight on them where as flex on the littlest thing. I just took my Jimmy out for the first time lastnight since the rollover, and I have new fenders on it, it rubbed going down a washboard road.
  13. Scooter
    Nov 18, 2000
    551
    Grandview, Mo.
    Actually, I bought the lift about 2 months ago and it has only been on the truck about 1 month. I haven't even put 1000 miles on it yet since the lift. I'm running 33's on the stock 15x8 rallys. The pic in my sig was taken at Potosi a couple weekends ago. The lift was on the truck less than 2 weeks and only street driven about 500 miles before the pic. Installed on the truck I netted just under 7" of lift. They're beginning to settle a bit now but not much (less than 3/4"). And it still rides very good, even better than it did stock.
    Scot in KC, MO
  14. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    DD, did your buddy reuse the old bushings or something. Or perharps he tightened the spring bolts with an impact. Something seems fishy about this truck. I got 35s and a 4" RC lift and I have the front and rear outer fenders trimmed just above the inner fenders and then beat the inners up to be even and I still rubbed my front at the same place Scooter did. RC flexes just as good as the rest IMHO.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  15. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I dont know for sure. He has had the lit on for about a year now, and he had his uncle do it for him so he doesnt know either. All I know is it sucks to dive and its way too stiff.
