Biggest tires on a stock 72
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tach, Jul 26, 2001.
  1. tach
    tach Registered Member
    Jun 23, 2001
    8
    What are the biggest tires I can run on a stock suspension '72 Blazer?
    '72 Blazer
  2. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    I got 32x11.5 on stock rims. No problemo.
    1972 K5
    1991 Jimmy
  3. Fish
    Fish Registered Member
    Jul 5, 2001
    34
    Michigan
    My buddy runs 33x12.5 BFG's. Other than winter driving, it doesn't see use off road. Not sure if there would be rubbing if he did. Looks real nice.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i was running 33x12.5 on stock. the rear tires did hit when i did some mild off roading. no problem with the front. I just put in a 2"body lift looks better and i think the rear tires may have a little more travel.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  5. 72blazer4x4
    72blazer4x4 Registered Member
    Jan 27, 2001
    60
    vacaville ca
    i also had 33x12.5 before i lifted it. i had the same problem with rubbing in the rear with mild off roading.
    jeremy
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    A friend has a Blazer with 33x12.50-15 BFG AT tires on 15"x8" Rallys and they seem to fit fine. He doesn't 'wheel it much, but he says that they did hit a couple of times.
    I have 32x11.50-15 Bridgestone MT tires on 15"x10" Eagle 063s and the when the front tires were pretty new, they would nail the "fang" when turned to about 2/3 lock in either direction. They don't hit now that they're pretty well-worn.
  7. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    I'm running 33x12.5's on 15x8 rims and I don't hit or rub at all. No fender trimming either. Of course the rear quarters were banged up pretty bad when I got it, and I haven't bothered to fix it so........?
  8. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    33x12.5 seem to hit when ran on 10" wide wheels....... ive seen some 32x12.5s on a stock height blazer and it looked to have plenty of room to flex
    also remember BFGs are ussaly closer to the actual height said on tire.... while "off brands" are ussaly smaller than said...
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, edelbrock performer intake+carb, MSD pro billet http://communities.msn.com/68K10
