biggest wheel/tire combo?
Discussion in 'The Garage' started by PDair, Dec 17, 2004.
  1. PDair
    PDair Registered Member
    Dec 17, 2004
    9
    McDonald
    What is the biggest wheel and tire combo that I could run with no rubbing on a stock 73-91 k5?
    Do you think I could run a 15x10 with a 33x12.50?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Without rubbing, no. Withuot rubbing you can probably get away with 31's. My 32's would rub with a 2.5" lift and no swaybar. If you run a swaybar you might get away with 32's and no lift but without a swaybar it will not clear when flexed moderately.
    33's can fit ok with some trimming and a swaybar. I would stick with 8" wheels though.
    Harley
  3. PDair
    Dec 17, 2004
    9
    McDonald
    I figured for mainly street driving I could run 33's
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The width is the killer. I had 255/85R16's on my 1-ton with bagged springs and no rubbing... tackling as much offroading as it could take. :D
    Maybe look at the 33x10.50 on 15x8 or 15x7 wheels.
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Once again, it almost matters more on rim width and BS than tire size. I run Q78-15 TSL's (36" tall, 10.75 wide") on 15x5.5 rims with ~3.75 BS, on just a 2" body lift and they dont rub, at all. You could get away with a 33x10.5 as long as the rims are narrow enough with no trimming and no rubbing. Confedneck ran 33x12.5 with no rubbing on his stock chevy, i forget the rims he ran.
  6. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    I have 33x12.50's on my stock rims-no lift...and it rubs with very mild flex (turning from the street into a driveway in town) they're not *new* tires, so imagine it would be worse if they were.
  7. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    i have a 4 inch tc lift its pretty old about 5-6 years old and 285/75/16 tires on a 16X8 and and if i jump a curb going kinda fast it will hit or if i flex alot especially with no swap bar.
  8. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    yes you can I did it on a 88
  9. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    I think a lot will depend on how your springs are and the bs of the wheels. I have a 90 with 33x12.50 on 15 x 10 wheels and no rubing. Even took it off road and only rubed once really flexing it out.
  10. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    My brother is running 33x10.5 Mall Terrains on Ralleys on his 87 K5. They come close at full turn, but don't rub.
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    :haha: :haha: :haha:
    Oh yeah... no swaybar either with 255/85R16's
  12. andy062202
    andy062202 Newbie
    Dec 15, 2004
    clarksville, tn
    I have 33x12.5 BFG Mud Terrains on stock wheels on my 1990 Blazer with no lift and have had no problems. I actually think I could fit a size bigger without rubbing too bad.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    On 10" wheels you'd be lucky to fit a set of 31x10.50s without rubbing. I sure could rub my 35s hard with 4" of lift on 10" wheels, even with the swaybar.
  14. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I don't think you want to go with a wheel larger than 8", if you want 33's & no lift.
  15. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Is the search feature broken or something?
  16. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    On my 91 (Jimmy) I run 35 X14's on a 10" rim with 3" b.s. with no lift , but to even get it out of the driveway I had to do a little trimming of the rear of the
    front fenders :D
    A short while later I beat the fronts of the fenders a little to stop a small amount of rubbing there
    BTW these tires are almost bald so I am certain that newer tires would rub alot more :tongue1:
    Have a good one:thumb:
  17. PDair
    Dec 17, 2004
    9
    McDonald
    Will it work if I run a 33x12.50 on a 15x8 w/3.25 BS?
    or I would prolly be better off with 3.75 or a 4.5 Backspacing.
  18. PDair
    Dec 17, 2004
    9
    McDonald
    I think I'm gonna go ahead and run a 285/75/16 tire on 16x10s with 4.5 BS when I get my k5.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A 285 tire is going to look awfully stupid on a 10" wheel. Run 8" wheels or 305/70s
  20. PDair
    Dec 17, 2004
    9
    McDonald
    everybody says that and see I personally think it looks fine heres a pic [​IMG]
