Bilstein 7100 Reservior Shocks.... outer shock body is what material???
Discussion in 'The Garage' started by Greg72, Mar 7, 2005.
  1. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    They look to be stainless, but before I ruin them by trying to clean off oxidation and crud with the wrong thing, I figured I'll ask....
    If they are stainless (they appear to be an unfinished metal of some sort with a slight "grain" machined or polished into them circumferentially) what material can I use? Some kind of ScotchBrite pad, 1500-grit wetsand paper, steel wool???
    :dunno:
    I got a set used for a good price, but they just look a little "skanky" so I'd like to make them more presentable before bolting them in.
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Fairly sure they arent stainless. I believe they are just plain ole steel with a nickel coat, machine finish, and some clear.
    Bilstein West: 1-858-386-5900
    Call them and ask them, hell they made them.
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    It's sounding like a "run of the mill" Chrome polish might be all it needs.... ???
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Go to a local truck stop or parts place and look for some stuff call "Magic Mix". It has a rabbit on a clear bottle(will look white since the stuff inside is white)..
    It is ok to use on any metal and painted surfaces(they say test it in a small area first), but it has worked great for me on everything I have used it on. Plus it does great polishing with little work... They also sell a metal cleaner in the same type bottle but it is pink fluid.
    This stuff works great for polishing aluminum!
