Bilstein shock question
Discussion in 'The Garage' started by unick, Oct 28, 2003.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Im thinking about putting bilstein 5150 or 6100 series shocks on my K5. I want the 14" travel ones. These shocks are 20.3" compressed. Would they fit on my truck with a 6" lift or would I have to relocate the shock mount?
    Also what vaulving should I get? I know its soposed to be different between the front and rear.
    thanx
    Nick
    lmk
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    thanx
    Nick
    lmk
    Nice member title /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Cycle the suspension real quick like and you can get an idea of what shock you need. And maybe this valving will get you close 275/78.
  3. unick
    Aug 16, 2003
    4,286
  4. unick
    Aug 16, 2003
    4,286
    come on guys i really need this info.
    thanx
    Nick
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    basically go with what bubba said...you will need to measure your suspension at rest and at full droop and full compression...make sure those distances are going to work
    Later
  6. Here's how to determine your valving . You'll need to know your what your spring rate is for this.
    My Blazer is at stock height right now. The shock length for the rear is 20 inches and the front measures 18. Add your lift amount to those numbers. To me it sounds like the shocks you're looking at will work for the rear, but the front may bottom out (it will only compress about 4 inches).
  7. unick
    Aug 16, 2003
    4,286
    I dont have the equipment to cycle the suspension here. Only place I could go would be the autohobby shop on base and im pretty sure they wont let me do cycle it there.
    well here r the specs for the shocks
    trav description valveing ext length col length
    14.53 5150 Crossflow 170/60 34.90 20.37
    14.53 5150 Crossflow 255/70 34.90 20.37
    If you r running these stock they should fit on my truck with 6" of lift right?
    lmk
    Nick
  8. unick
    Aug 16, 2003
    4,286
    also im gonna have superlift or skyjacker front springs and whichever rear springs come with the ak57 sus
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm going with Bilstein 5100 12" travel front shocks and Bilstein 5150 14" travels in the back. Whats your rear suspension setup? if its just a stock spring with shackle flip setup you won't really need 14" travel. I won't be buying shocks till after the K5 is pretty well done and hits a ramp to check measurements. I'm planning 255/70 in the front and 170/60 in the back but I'm running BDS front springs which are a little softer than Skyjacker and definetally softer thatn Superlift. Superlift vs Skyjacker is a big jump. You really need to listen to the advice here, this stuff is a case by case basis, places that sell the shocks try and make it seem too universal.
  10. unick
    Aug 16, 2003
    4,286
    im gonna be using the AK57 rear suspension thats why I need the long travel shocks.
    Nick
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    talk to marv, he was giving me advice about what I should run shockwise. I think his recomendation was something like 150/60 valving with 57" ford springs and 14" travel would work out with the springer.
  12. unick
    Aug 16, 2003
    4,286
    alright then thanx for the info
