Bilstein shocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by onlychevy6, Jul 10, 2003.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    i am interested in using the bilstein shocks in my 78 blazer. the problem i have come across is this. after speaking to bilstein direct they do not make a factory type shock for lifted trucks only stock height. so i was told i need to get the fully colapsed and extended length of the shock i need and i woould be able to use there 5100 series shocks. does any have any idea what the lengths should be or have done this before? i have a 6 inch superlift suspention on 35" tires and i DO NOT have a body lift.... /forums/images/graemlins/thinking.gif
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    You need a ramp and a tape measure...
    Remove existing shocks, then max out your suspension's stuff and droop and take the measurements at the shock mounts. You don't want to "top out" or "bottom out", and a couple of inches of margin would be nice on both conditions....
    Marv
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Thanks for asking /forums/images/graemlins/thumb.gif I was just getting ready to post the same question for a 4 inch lift
    I'll just bum a ride from you /forums/images/graemlins/deal.gif
  4. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    thanks marv for you response. now as far as a ramp is concerned what type of ramp do i need? or should i try to contact a local off road club? Such as So Cal Big Dawgs. they are a local off raod club here in southern calif.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The So-Cal Dawgs have a ramp that they might be willing to pull out for you to use. Some off road shops have ramps too. </font>
  6. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I've got 4" Skyjacker springs F and R on my '87K5. Bilstein has shocks for a 4" lift. Part numbers are:
    rear F4-BE5-6248-HO
    front F4-BE5-6253-HO
    Rear is good but front was too bouncy for me. So I added
    one RS5000 shock to each Bilstein in the front.
