.bin
Discussion in 'The Injection Section' started by southernspeed, Jul 23, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    '91 7747 ecu for a 350" truck, is the stock bin a asdz or asdz_42 ?
  2. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    I think there both the same.
    KM
  3. dyeager535
    26,980
    Sorry too lazy to go research it (actually just a very slow internet connection) but I suspect the x_42 probably just indicates the mask.
    ASDZ is actually the broadcast code, (BCC) but obviously the .bin is typically labeled with that, and the broadcast code was specific enough that you won't see the same broadcast code with different masks. (at least that I know of)
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks Dorian. I've tried searching for it but obviously not in the right places. I've compred the two .bins on my CATS programme and can't actually see any differences. I just wanted to make sure before I start messing around with them.
    I'm a real nube to burning so 'masks' etc are all Russian to me at the moment. I really need to put some time aside and sit down to read all that thirdgen sticky stuff again.
  5. Creek
    Creek Registered Member
    Mar 17, 2006
    36
    Mint Hill, NC
    To my knowledge all GM codes were either three or four letter codes. The _42 was probably added by someone who saved the bin and posted it on the net. I would think the _42 references the $42 program id. I've found a few asdu bins with additional characters or numbers that are the same as the standard asdu bin. Your safest bet is to upload the file from your stock eprom.
    David
