binding after a 4" lift
Discussion in 'The Garage' started by thegreatwhiteheap, Dec 19, 2005.
  1. thegreatwhiteheap
    thegreatwhiteheap Registered Member
    Dec 14, 2005
    15
    southern florida
    i recently bought a 74 blazer with a 4" lift and 33s. im want ot go back to stock height. i know that sometimes there are problems with binding and drive shafts when lifts are put in (but not always) and sometimes shims are needed to correct shaft angles. im pretty inexperienced with suspensions and because i bought it with this lift kit already in it i have nothing to compare it against, so, i was hoping maybe someone had a before and after pic of what any parts that would need shimms would look like so i could see if my truck has any taht need to be removed so as to not run into problems when bringing it back down. also, is there any way to tell if the drive shaft has been lenghthened? and lastly, will i run into clearence issues with the same 33s on at stock height? or do i jsut have to wait and see?
    thanks for any help!!
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Well one simple trick you can do as you begin to "unlift" your truck is to get a Sharpie and mark the slipjoint where it enters the yoke....then measure out about 1" and mark that spot (with a 1" notation), go out another inch and mark it (2").
    Depending on what the existing setup is...your driveshaft might get shorter or longer. Making a few reference marks will allow you to see which direction (and to what extent) the driveshaft length has changed.
    After that, you might want to take the driveshaft out and measure how much total slip it has...and figure out if you've got a useable amount or if it's nearly "bottomed out" or "topped out".
    Unfortunately, it's pretty tough to calculate ahead of time where your driveshaft lengths are going to end up. Most of the time, you just have to make the suspension changes you want, and then measure the distance (yoke to yoke) that you end up with and go from there.... :confused:
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    the driveshaft should still be the stock length for a 4" lift. How come ur taking it out?
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey man, where in VA are you?
    i dont think you will have any binding with just 4" lift. most ppl dont notice anything til at least 6".
  5. echos
    echos Registered Member
    Nov 21, 2005
    28
    MD-Phoenix someday soon
    I have a stock hieght gmc shortbed, bring yours up to maryland and we can trade lifts.
  6. thegreatwhiteheap
    Dec 14, 2005
    15
    southern florida
    what about drive shaft angles though? with shims and what have you (oh and there is only a block under the rear, does that change anything?)
    muddybuddy-im in leesburg.
    echos-i already have the front springs but i need shocks and possibly rear spings and if you got aftermarket stock length ones i WILL trade you!
  7. echos
    Nov 21, 2005
    28
    answered your email, maybe we can work it out
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright, thats not too far out, im in fairfax
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Is this before you "slam"it?
  10. thegreatwhiteheap
    Dec 14, 2005
    15
    southern florida
    eventually, but id have to modifythe frame.
    for right now im jsut wanting stock height and possibly dump it later in life.
  11. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i am in hamilton , right down the road from leesburg. do you need help removing it? maybe we can all get together and knock this out .
    unfortunatly, i have gotten rid of all my stock parts after i lifted mine.
