binding when wheels are at full turn???
Discussion in 'The Garage' started by 85 Jimmy, Feb 14, 2007.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    ok guys, for some reason at full lock of the steering wheel to either side something's binding, maybe not binding but when the wheels turned all the way it doesn't just keep rolloing like it used to, i have to give alittle gas and once i let up it stops... but only in 4x4 and only when the hubs are locked
    i looked underneath to see if i could see anything and everything looked ok.
    i noticed this today after i installed my square front driveshat and i didn't ever notice it before with the regular d-shaft.
    could it be the square shaft???
  2. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    It will bind up if the hubs are locked and the T-case is in 4-wheel drive and you are trying to do this on dry pavement. Its normal. I bet if you go do it on the dirt or snow it wont bind.
  3. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i wasn't on dry pavement, i was in a feild and then in the middle of a semi mud pit...
  4. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Your new front shaft could be binding at the U-joints.
    -- A
  5. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i checked that today, i went out to a feild and was looking at everything, if the hubs are locked it does it, it can be in 2 wheel drive but if the hubs are locked it does it... but i did find that the cap to my manual locking hubs on the driver side was alittle loose :dunno:
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Bad u-joints in the axle shafts can do that. Mine did it real bad when the joints rusted up in the D60.
    They were probably at least 10 years old when I changed them. Took over 4,000 Lbs of pressure from the press to get them to budge.
  7. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    hmm... i just put new u-joints in there not even 5,000 miles ago
  8. readymix
    May 30, 2004
    6,706
    26
    Put the front up on jack stands and move everything around to check it out.
    By move it around I mean by hand.....not under power from the motor. Think SAFETY
