black fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Jan 5, 2004.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I have a 12 bolt rear with an eaton posi in it. when I checked the rear the fluid was black. No flakes of metal at all. I put in posi additive and 80w90 gear oil. Why would the fluid be black? Thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The fluid is probably just old. I just got a 12 bolt with dark fluid too. Just change it and your seals while your at it. /forums/images/graemlins/k5.gif
  3. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The fluid was put in new with the new eaton in 2003 over the summer.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    You sure it was black? I know different manufacturer's sometimes have different colors- I know when my rear end got refilled, the lube my mechanic used was dark blue. When i changed it, mine was like motor oil colored with a tad of green hint.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    gear oil mixing with LS additives can cause fluid discoloration, try an experiment in a plastic bottle and mix a little of each..see what happens.. /forums/images/graemlins/thumb.gif
  6. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    it still smelt like gear lube, not burnt. Hopefully it is the mixing of the two fluids. Thanks.
