black junk on the wheels
Discussion in 'The Garage' started by adamforsythe, Jun 26, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well I am polishing up my wheels because they are dirty. Well they have this black crap on them it's kinda like the rubber that you find on the road. Well I got 65% of it off, the wheels look good but I want them to look real nice. What do you guys use to clean up a wheel?
    ADam
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Brake dust..................
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    yeah thats brake dust from your brake pads burning up.. just keep cleaning them with any strong house hold cleaner.
  4. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    get a nice wheel acid from your local auto store. make sure it's safe to use on your wheels though.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Go to a truck wash every now and then.
  6. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I use a variety of stuff, NeverDull, Eagle1 brake dust remover spray on stuff, Mothers Chrome wax. Typically I wash my rigs every two weeks so they never get very bad.
  7. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Dirty wheels
    Castrol makes this purple stuff degreaser that takes that crap right off, but may not be too safe on really nice rims. Simple green works pretty good to and is safe on just about everything. I spray it on at the DIY high pressure car wash, and have at it, zip-zip, it is done.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The best brake dust remover that I've tried is Armor All Quicksilver. Spray, rinse, and wipe. The wheels look much better! None of the other wheel cleaners that I tried seemed to make much difference.
    Since you live in Maine, I'm guessing that your wheels also see LOTS of road salt. That stuff turns aluminum into a black, crusty mess. I once cleaned up a set of wheels that were pretty corroded by using a kitchen/bar cleaning product called Cameo. It's made for cleaning aluminum. It will remove the corrosion (with the proper amount of elbow grease added ;) ) But it also dulls the shine of the aluminum so you have to follow up with a good aluminum polish to make them look good again.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the salt eats the coating off the aluminum so they will corrode
    they are all corroded here, cant keep aluminums on a DD unless you just dont drive it during winter or polish them everyday maybe
    the mags on my 81 c-10 are totally missing the coating form about 3" of the outer diameter of the wheels, totally eaten away gone and are dull black pitted but they are light and they actually fit the hubs tight like factory rims do,so im leaving them on there the tires are 31 x 10.50 RVT's though, too much for the little c-10 with its 2.73 gears its a dog, the poor old 350 doesnt get any rpm going at all,
    you can buy brake dust shields for wheels.,
    summit and etc,
    good luck
  10. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Brake cleaner... spray it on and use steel wool to rub off all the crap.
